Scroll text using I2C SH1106
soggycashew
Post by soggycashew » Tue Jan 11, 2022 7:14 pm
Hello, I'm using the sh1106 library from github and I needed my text to scroll vertically down and off screen and start over at top again. How is this done?
Thanks!
from machine import I2C
import utime
from sh1106 import SH1106_I2C
i2c = I2C(0, sda=machine.Pin(4), scl=machine.Pin(5), freq=400000)
display = SH1106_I2C(128, 64, i2c)
display.sleep(False)
display.fill(0)
display.text('Testing 1', 20, 0, 1)
display.text('Testing 2', 20, 12, 1)
display.text('Testing 3', 20, 24, 1)
display.text('Testing 4', 20, 36, 1)
display.text('Testing 5', 20, 48, 1)
display.show()
scruss
Re: Scroll text using I2C SH1106
Post by scruss » Wed Jan 12, 2022 3:52 am
the SH1106 library inherits scroll() from the framebuf library
soggycashew
Post by soggycashew » Wed Jan 12, 2022 5:44 pm
If anyone is interested I found the answer...
Continuous vertical scroll
If you want to scroll the screen in and out vertically continuously, you
can use the scroll_in_out_screen_v(screen) function.
# Define GPIO pins
oled_width = 128
oled_height = 64
oled = SH1106_I2C(oled_width, oled_height, i2c)
screen1_row1 = "Screen 1, row 1"
screen1_row2 = "Screen 1, row 2"
screen1_row3 = "Screen 1, row 3"
screen2_row1 = "Screen 2, row 1"
screen2_row2 = "Screen 2, row 2"
screen1 = [[0, 0 , screen1_row1], [0, 16, screen1_row2], [0, 32, screen1_row3]]
screen2 = [[0, 0 , screen2_row1], [0, 16, screen2_row2]]
#Define Functions
def scroll_screen_in_out_v(screen):
  for i in range (0, (oled_height*2+1), 1):
    for line in screen:
      oled.text(line[2], line[0], -oled_height+i+line[1])
    oled.show()
    if i!= oled_height:
        oled.fill(0)
# Continuous verticall scroll
    scroll_screen_in_out_v(screen1)
    scroll_screen_in_out_v(screen2)
scruss
Post by scruss » Fri Jan 14, 2022 3:29 am
I ran the following on an SSD1306, which should have a very similar API as the SH1106:
import s2mini  # on Lolin ESP32-S2 Mini
import ssd1306
WIDTH = 64  # screen size
HEIGHT = 48
SIZE = 8  # text size
# set up and clear screen
i2c = I2C(0, scl=Pin(s2mini.I2C_SCL), sda=Pin(s2mini.I2C_SDA))
oled = ssd1306.SSD1306_I2C(WIDTH, HEIGHT, i2c)
oled.fill(0)
n = 0
    oled.scroll(0, -SIZE)  # scroll up one text line
    oled.fill_rect(0, HEIGHT-SIZE, WIDTH, SIZE, 0)  # blank last line
    oled.text("%8d" % n, 0, HEIGHT-SIZE)  # write text
    oled.show()
    n = n+1
The procedure seems to be:
  1. scroll the display up one line
  2. blank out the last line
  3. draw your text on the last line
soggycashew
Post by soggycashew » Fri Jan 14, 2022 5:05 am
@scruss i have everything working except i cant figure out how to update my sensor data. I posted this question in a separate thread HERE
