[Solved] Connect PICO with DS1302
Patriboom
Post by Patriboom » Tue Feb 08, 2022 5:32 am
Hello everyone,
I've found only one source to connect DS1302 and it is with a Microbit microcontroller.
( https://github.com/shaoziyang/microbit- ... isc/DS1302 )
I now try to built the corresponding repository for PICO
( https://github.com/Patriboom/DS1302_Python_RaspPICO )
I've never touch a Microbit MC, but according to the pinout I found ( https://www.microbit-spy.co.uk/wp-conte ... pinout.png )
The pinning goes as the folling:
Microbit Description PICO PIN
clk=pin13, SPI-1.SCK 14:SPI-1.SCK 10
dio=pin14, SPI-1.MIS0 15:SPI-1.TX 11
cs=pin15 SPI-1.MOSI 16:SPI-1.RX 12
Trying to reproduce the same logical, I did the following pinout on Rasp PICO
DS1302 PICO
VCC 39: VSYS
GND 38: GND
CLK 14: SPI1.SCK -- GP 10
DIO 15: SPI1.TX -- GP 11
CS 16:SPI1.RX -- GP 12
It didn't work.
I thought to have connected Rx and Tx on reverse then I connected as:
DS1302 PICO
VCC 39: VSYS
GND 38: GND
DIO 15: SPI1.RX -- GP 12
CS 16:SPI1.TX -- GP 11
No better chance.
Always such error message:
File "", line 20, in
File "DS1302.py", line 99, in Hour
File "DS1302.py", line 62, in getReg
File "DS1302.py", line 53, in read_byte
TypeError: unsupported types for lshift: 'Pin', 'int'`
Any help will be very appreciate
scruss
Re: Connect PICO with DS1302
Post by scruss » Tue Feb 08, 2022 4:46 pm
Patriboom
[Solved] Re: Connect PICO with DS1302
Post by Patriboom » Tue Feb 08, 2022 7:31 pm
Nice!
Thanks,
I've never found it !
Patriboom
Post by Patriboom » Tue Feb 08, 2022 7:58 pm
Looks very good.
But, still .. I have no communication.
My pinout is:
DS1302 -> PICO
CLK -> 14: SPI-1.SCK
DAT -> 15: SPI-1.TX
RST -> 16: SPI-1.RX
I also tried
DS1302 PICO
DAT -> 16: SPI-1.RX
RST -> 15: SPI-1.TX
The code goes like:
import ds1302
ds = ds1302.DS1302(Pin(14),Pin(15),Pin(16))
ds.date_time([2022, 2, 8, 3, 14, 23, 1, 0]) # set datetime.
hre = ds.date_time() # returns the current datetime.
print(hre)
print(ds.hour()) # returns hour.
print(ds.second()) # set second to 10.
Have I to set the pins like this:
ds = ds1302.DS1302(Pin(13),Pin(14),Pin(15))
The result is always:
%Run -c $EDITOR_CONTENT
[2165, 165, 165, 165, 165, 165, 45]
165
45
Note: that is the same result as if I plugged nothing at all.
Thanks again.
Patriboom
Post by Patriboom » Tue Feb 08, 2022 9:23 pm
It works now!
Same pinout as above:
DS1302 ---> PICO
GND ---> GND
VCC ---> VSYS
CLK ---> 14.GP_10; SPI-1SCK
DAT ---> 15.GP_11; SPI-1TX
CS ---> 16.GP_12: SPI-1RX
with the following code
import ds1302
ds = ds1302.DS1302(Pin(10),Pin(11),Pin(12))
print(hre)
