axtls on raspberry pi pico
ekkim
Post by ekkim » Fri Feb 11, 2022 6:16 am
I already added the library of wiznet5k(ethernet) on raspberry pi pico board.
I want to use the ssl protocol on raspberry pi pico board.
As a result of searching within the micropython code for that content, it seems that axtls and mbedtls can be written.
I have selected axtls library used by esp and I am porting it.
If I send a lot of data using the code, the process appears to be stopped. If you do a ping test at this time, it is normal.
mutex problem? irq problem?
When rp2040 read the data using SPI interface....
I set the tx_buf[100] and I send a lot of data using the code, the process appears to be stopped.
but I set the tx_buf[4096] and I send a lot of data using the code, the process seems to have stopped intermittently.
STATIC void wiz_spi_read(uint8_t *buf, uint32_t len) {
    //uint8_t tx_buf[100];
    uint8_t tx_buf[4096];
    machine_spi_transfer((mp_obj_base_t*)wiznet5k_obj.spi ,len, tx_buf ,buf);
source code link : https://github.com/Wiznet/RP2040-HAT-MicroPython
mrpackethead
Re: axtls on raspberry pi pico
Post by mrpackethead » Sat Mar 26, 2022 9:08 pm
where you able to resolve this?
I'm trying to figure out how to use MBEDTLS on an RP2040
