ImportError: no module named 'uwebsocket'
aroca
Post by aroca » Sun Feb 13, 2022 11:46 am
I am trying to build MicroPython v1.18 with WebREPL and Ethernet for the WIZnet W5100S-EVB-Pico. My starting point is this repository: https://github.com/Wiznet/RP2040-HAT-MicroPython.
The build works fine and Ethernet works. Next, I tried to add WebREPL support by adding this line to the manifest file:
include("$(MPY_DIR)/extmod/webrepl/manifest.py")
The build also works and webrepl is available, however, there are 2 issues:
The first:
MPY: soft reboot
MicroPython v1.18-10-g5db278f1d-dirty on 2022-02-12; Raspberry Pi Pico with RP20
>>> import webrepl
File "webrepl.py", line 5, in <module>
>>> help('modules')
__main__ math uasyncio/stream ure
_boot micropython ubinascii uselect
_onewire neopixel ucollections usocket
_rp2 network uctypes ussl
_thread onewire uerrno ustruct
_uasyncio rp2 uhashlib usys
builtins ssd1306 uheapq utime
cmath uarray uio uzlib
dht uasyncio/__init__ ujson webrepl
ds18x20 uasyncio/core uos webrepl_setup
framebuf uasyncio/event upip websocket_helper
gc uasyncio/funcs upip_utarfile
machine uasyncio/lock urandom
Plus any modules on the filesystem
I verified the compilation process and the file moduwebsocket.c is compiled and linked during the compilation process. I verified the builds for ESP32 and ESP8266 and moduwebsocket.c seems to be compiled and linked in a similar way. However, on the ESP32 and ESP8266 uwebsocket appears when I run the command help('modules').
Manifest files are the same for the ESP32, ESP8266 and RPI Pico.
The other issue is a minor detail:
>>> import webrepl_setup
File "webrepl_setup.py", line 67
SyntaxError: invalid syntax
Any help will be great. Having WebREPL over ethernet on the Raspberry Pi Pico would be very nice.
best regards and thanks!
Rafael
