Pi pico uart 1 seems to not work
minthemerciless
Post by minthemerciless » Wed Feb 16, 2022 11:36 pm
Hi all,
New here, long background of software development, but not in python/ micropython, long background of embedded development, but not with the 'new' pi pico.
I'm using the pi pico, running micropython, with the Thonny 'IDE'.
I'm trying to get the pico to behave as a kind of serial gateway, with data coming in on uart0, and either do some stuff with it, or pass it on to uart1, and visa versa.
What I'm struggling with is getting uart1 to work at all. I can successfully get uart0, using GP0 and GP1 pins, all fine. If I swap the exact same code to uart1, GP4 and GP5, or GP8 and GP9, it doesn't work.
This is being done using Thonny with it connected and reading 'print' data.
What I don't know is where the print data is being transmitted from on the pi pico. Is this using uart 1, which is why it doesn't work out of the box?
It would be great to know if anyone has managed to get both uart0 and uart1 working, at the same time, on a pi pico, running micropython.
Or if there are any caveats to using both uart ports at once.
Any info is greatly appreciated :)
Re: Pi pico uart 1 seems to not work
Post by pythoncoder » Thu Feb 17, 2022 9:37 am
My standard loopback test works fine on UART 0 and 1 (link pins 4 and 5 for UART 1):
import uasyncio as asyncio
uart = UART(1, 9600)
async def sender():
    swriter = asyncio.StreamWriter(uart, {})
        swriter.write('Hello uart\n')
        await swriter.drain()
        await asyncio.sleep(2)
async def receiver():
    sreader = asyncio.StreamReader(uart)
        res = await sreader.readline()
        print('Recieved', res)
async def main():
    asyncio.create_task(sender())
    asyncio.create_task(receiver())
        await asyncio.sleep(1)
def test():
        asyncio.run(main())
    except KeyboardInterrupt:
        print('Interrupted')
    finally:
        asyncio.new_event_loop()
        print('as_demos.auart.test() to run again.')
test()
Post by Roberthh » Thu Feb 17, 2022 9:42 am
@minthemerciless Can you show a simple code example that fails?
@pythoncoder Did you try using uart0 and uart1 at the same time?
Edit: As simple test here works fine, sending & receiving data between UART0 and UART1.
Post by pythoncoder » Thu Feb 17, 2022 10:18 am
The following works, either with both uarts looped back, or with them cross-linked (GPIO 0-5 and 1-4 linked):
uart0 = UART(0, 9600)  # Wire GPIO 0-5 and 1-4
uart1 = UART(1, 9600)
async def sender(uart, n):
        swriter.write(f'Hello from uart{n}\n')
async def receiver(uart, n):
        print(f'Recieved by uart{n}', res)
async def main():
    n = 0
    for uart in (uart0, uart1):
        asyncio.create_task(sender(uart, n))
        asyncio.create_task(receiver(uart, n))
        n += 1
def test():
        asyncio.run(main())
    finally:
test()
minthemerciless
Post by minthemerciless » Thu Feb 17, 2022 12:15 pm
Hi, thanks for the assist guys!! Really appreciate it.
I took my set up apart. Wired it up for the supplied loopback test. All worked fine. So not my hardware.
I put my code back on, and as if by magic, jackpot! It all worked as expected.
The solution?...
I will, hang my head in shame and admit it. In a blind stupor last night trying to get stuff working I had completely missed the fact that the labels on the board are GPx, not pin X. So when reading the pinout, seeing GP4,5 maps to pin 6 and 7 on the board, I'd connected my uart 1 to pins 6 and 7 completely neglecting the fact that is says GP6,7. IDIOT!! :oops:
Note to self: check my wiring.
