Hello pythoncoder,
I have been trying to understand your code and incorporate with push button inputs to change the frequency of the waves generator. For now I am still not able to change the frequency while the audio engine is working, however I am now able to use uasyncio to do other stuff at the same time.
Can you take a look at my code and see how can the play() function update the new frequency after I press a button?
Here is my play() function:
playing = True
freq = 330
old_freq = 0
async def play(fo, wname):
global freq
global old_freq
while playing == True:
if old_freq != freq:
buflen = 2 * populate(fo, wname) # execute only when there is a frequency change
old_freq = freq
# HACK awaiting https://github.com/micropython/micropython/pull/7868
swriter.out_buf = samples_mv[:buflen]
await swriter.drain()
Here is my main code with the multiple coroutines running along with the audio engine:
import uasyncio as asyncio
import awg
# Settings
led = Pin(2, Pin.OUT)
btn = Pin(0, Pin.IN, Pin.PULL_UP)
ticks = 0
def button_interrupt(pin): # Pressing the button increases the frequency +40
global freq
awg.freq += 40
print("freq = ", awg.freq)
btn.irq(trigger=Pin.IRQ_FALLING, handler=button_interrupt)
async def counter(period_ms):
global ticks
ticks += 1
print(ticks)
ticks %= 16
await asyncio.sleep_ms(period_ms)
async def blink(period_ms):
if led.value() == 0:
led.value(1)
led.value(0)
async def monitor_input(period_ms): # monitors the current frequency
print("frequency now = ", awg.freq)
await asyncio.sleep(period_ms)
async def main():
asyncio.create_task(counter(500))
asyncio.create_task(blink(250))
asyncio.create_task(monitor_input(5))
asyncio.create_task(awg.play(awg.freq, "saw"))
print('Tasks are running')
await asyncio.run_until_complete()
asyncio.run(main())
finally:
awg.audio_out.deinit()
asyncio.new_event_loop() # Clear retained state
I am sure that looking at my code you realise I am very "green" to all this.
Overall, what I am trying to achieve is to be able to update the fo, wname with button presses and encoders. Do you think this can be achieved?
