Hello everyone I have been working on this library I found over github to use an ADS1115 at 860s/s to sample a 140Hz data.
ADS1115 Library: https://github.com/robert-hh/ads1x15
In the timmer part I need to use a timer with the period of 0.01ms to get an accurate sample. With 1ms timer I am only able to sample a 50Hz signal at 860s/s. Here is the part for the timer:
ads.set_conv(7,0)
ads.read_rev()
sleep_ms(5)
tim = Timer(-1)
tim.init(period=1, mode=Timer.PERIODIC, callback=sample) ------> 1 corresponds to 1ms the lowest this function can take!
Having Issues with ADS1115 and Timer
Re: Having Issues with ADS1115 and Timer
The time for two way communication has to be added to the total cycle time. You can save some time by using the adc.set_conv() and adc.read_rev() methods, which starts a new cycle when reading the actual value. Or you use continuous reading with a trigger on the alert/Rdy pin to a Pin IRQ. Examples are provided in the readme.md of the ADS1115 repo. The RPI should be fast enough to cope with the data rate.
Thank you so much for your fast reply!
Here is my adjusted code:
def sample(adc = ads.read_rev, data=data, timestamp = timestamp, voltage=ads.raw_to_v):
global index_put, irq_busy
for i in range(860):
if irq_busy:
return
irq_busy = True
ads.set_conv(7, 0)
if index_put < _BUFFERSIZE:
data[index_put] = ads.read_rev()
index_put += 1
i +=1
irq_busy = False
irq_busy = False
index_put = 0
I am using a 40Hz Sine with the amplitude of 2V and here is what I get:
2015 cla 250 0 60
It is surprising since I have the sampling rate set to 860s/s.
Any idea?
Thanks again,
Andromeda
if irq_busy:
return
irq_busy = True
ads.set_conv(7, 0)
index_put += 1
i +=1
irq_busy = False
irq_busy = False
index_put = 0
2015 cla 250 0 60
Any idea?
Thanks again,
Andromeda
What is surprising? I did a similar set-up. Results below. The actual sampling rate is 835 sample/sec. The sampling rates you get are not precise, since they are define by the internal oscillator of the ADS1115, which is about 1 MHz, but varies with temperature and device.
Another snapshot, using the timer variant of the sampling, at 500samples/sec. Code and 40Hz sample below. To get a faster sampling, like 750 samples/sec. You would have to use PWM to create a 750 Hz pulse and a IRQ interrupt to do the sampling. With Timer/PWM controlled sampling, the rate is pretty precise.
from machine import I2C, Pin, Timer
import ads1x15
from time import sleep_ms, ticks_ms, ticks_us
from array import array
addr = 72
gain = 1
_BUFFERSIZE = const(512)
# Interrupt service routine zum messen
# diese wird vom Timer-interrupt aktiviert
def sample(x):
global index_put, ads, irq_busy, data, timestamp
if irq_busy:
return
irq_busy = True
timestamp[index_put] = ticks_us()
index_put += 1
irq_busy = False
data = array("h", [0] * _BUFFERSIZE)
timestamp = array("L", [0] * _BUFFERSIZE)
irq_busy = False
index_put = 0
ADC_RATE = 2
i2c = I2C(0, freq=400000)
ads = ads1x15.ADS1115(i2c, addr, gain)
# set the conversion rate tp 860 SPS = 1.16 ms; that leaves about
# 800µs time for processing the data with a 2 ms timer
ads.set_conv(7, 0) # start the first conversion
ads.read_rev()
sleep_ms(ADC_RATE)
tim = Timer(-1)
tim.init(period=ADC_RATE, mode=Timer.PERIODIC, callback=sample)
while index_put < _BUFFERSIZE:
pass
tim.deinit()
for _ in range(1, _BUFFERSIZE):
print(timestamp[_], timestamp[_] - timestamp[_-1],
data[_], data[_] - data[_ - 1])
# at that point data contains the sampled values, and
# timestamp the timer ticks which correlate to the conversion time
Another picture, this time of a 140 Hz signal, sampled at 500Hz, interpolation with cubic spline. The dots show the actually sampled values. The fastest conversion time of the ADC is about 1/860 second. That's the limit. The other limit would be the communication time ar read_rev(), which is about 400 µs. The latter could be shortened by setting the CPU freq to 250Mhz and the I2C freq to 2 Mhz to about 130 µs. But the conversion time of the ADC stays. If that is too slow, you have to use a differerent ADC.
