Values wont update
Posted: Sat Mar 19, 2022 3:18 pm
Hello, I have a 4 plant moisture and humidity meter on a Pico and everything runs fine when the btn_show_display is pressed BUT my values never update on the oled (Unless I stop the program and rerun). What it does when I press the button it displays temp and humidity then shows each plants capacitive soil sensors moisture percent based off the Wet/Dry Baseline Readings in the code and loops twice and shuts off oled until I press the button again and it loops again displaying the values.
What in the code do I need to change to update the values on the fly OR when the button is pressed? Please give me an example I'm new to this... Thanks!
Attached is the .py in a .zip
import machine, time, uasyncio
from primitives.pushbutton import Pushbutton
from machine import I2C
from ads1x15 import ADS1115
from sh1106 import SH1106_I2C
from dht22 import DHT22
# Define/Initialize GPIO Pins
i2c2 = I2C(0, sda=machine.Pin(0), scl=machine.Pin(1), freq=400000)
dht22 = DHT22(machine.Pin(2,machine.Pin.IN,machine.Pin.PULL_UP))
btn_show_display = machine.Pin(3, machine.Pin.IN, machine.Pin.PULL_DOWN)
led = machine.Pin(25, machine.Pin.OUT)
# Define Functions
# Calculate the percentage between the wet/dry values
def percentage_value(value, in_min, out_max, out_min):
percentage_value = (value - in_min) / (out_max - out_min) * 100
return (str(round(percentage_value))) + "%"
# Scroll in OLED screen vertically
def scroll_in_screen_v(screen):
for i in range (0, (oled_height+1), 1):
for line in screen:
oled.text(line[2], line[0], -oled_height+i+line[1])
oled.show()
if i!= oled_height:
oled.fill(0)
# Scroll out OLED screen vertically
def scroll_out_screen_v(speed):
for i in range ((oled_height+1)/speed):
for j in range (oled_width):
oled.pixel(j, i, 0)
oled.scroll(0,speed)
oled.show()
# Define Variables
wet = 11344 # Wet Baseline Reading
dry = 22283 # Dry Baseline Reading
# -----------------------------------ADC Converter
adc0 = ADS1115(i2c2, 0x48, 1) # Pins, 1st ADC Address, Gain = 1
# -----------------------------------OLED Display
oled_width = 128 # Width of OLED screen
oled_height = 64 # Height of OLED screen
oled = SH1106_I2C(oled_width, oled_height, i2c2)
# -----------------------------------Temperature & Humidity Sensor
T, H = dht22.read() # Gets Temp & Hum from dht22.py library
temp_f = T * (9/5) + 32.0 # Converts the (T) temperature to Fahrenheit degrees
# Analog-to-Digital ADC PGA Converter ADS1115--------------
adc0_result_A0 = percentage_value(adc0.read(0, 0), dry, wet, dry)
adc0_result_A1 = percentage_value(adc0.read(0, 1), dry, wet, dry)
adc0_result_A2 = percentage_value(adc0.read(0, 2), dry, wet, dry)
adc0_result_A3 = percentage_value(adc0.read(0, 3), dry, wet, dry)
# %m.kf Converts a value of type float (or double) to m decimal positions with k digits after the period.
OLED_screen1 = [[0, 18 , "Temp: %3.0fF" %temp_f], [0, 34, "Humidity: %3.0f%%" %H]]
OLED_screen2 = [[0, 2 , "Pot 1: " + str(adc0_result_A0)],
[0, 18, "Pot 2: " + str(adc0_result_A1)],
[0, 34, "Pot 3: " + str(adc0_result_A2)],
[0, 50, "Pot 4: " + str(adc0_result_A3)]]
# -----------------------------------uasyncio Coroutine
# Coroutine: blink on a timer
async def blink(delay):
led.toggle()
await uasyncio.sleep(delay)
async def wake_oled(): # Runs when button pressed
for i in range(2):
# Scroll in, stop, scroll out (vertical)
scroll_in_screen_v(OLED_screen1)
await uasyncio.sleep(5) # Sleep for 5 seconds (must use async sleep)
scroll_out_screen_v(2)
scroll_in_screen_v(OLED_screen2)
# Coroutine: entry point for asyncio program
async def main():
pb = Pushbutton(btn_show_display) # Create pushbutton instance
pb.press_func(wake_oled)
# Start coroutine as a task and immediately return
uasyncio.create_task(blink(0.2))
await uasyncio.sleep(1) # You can run other code here
# Start event loop and run entry point coroutine
uasyncio.run(main())
