I experimented with programming a quadrature encoder for RPI2040 PIO, inspired by
https://github.com/GitJer/Rotary_encode ... ncoder.pio and later
https://github.com/raspberrypi/pico-exa ... ncoder.pio.
I have two solutions now and a number of questions:
First solution:
# Quadrature encoder for RPi 2040 Pio
# Has to be at address 0 of PIO programm space
# Original version (c) 2021 pmarques-dev @ github
# (https://github.com/raspberrypi/pico-examples/blob/master/pio/quadrature_encoder/quadrature_encoder.pio)
# Adapted and modified for micropython 2022 by rkompass
# SPDX-License-Identifier: BSD-3-Clause
# This program was reduced to take 'only' 24 of 32 available PIO instructions.
# Quadrature encoding uses a state table in form of a jump table
# which is fast and has no interrupts.
# The counter x is permanently pushed nonblockingly to the FIFO.
# To read the actual value empty the FIFO then wait for and get the next pushed value.
# The worst case sampling loop takes 14 cycles, so this program is able to read step
# rates up to sysclk / 14 (e.g., sysclk 125MHz, max step rate = 8.9 Msteps/sec).
from rp2 import PIO, StateMachine, asm_pio
from time import sleep_ms
class PIO_QENC:
def __init__(self, sm_id, pins, freq=10_000_000):
if not isinstance(pins, (tuple, list)) or len(pins) != 2:
raise ValueError('2 successive pins required')
pinA = int(str(pins[0]).split(')')[0].split('(')[1].split(',')[0])
pinB = int(str(pins[1]).split(')')[0].split('(')[1].split(',')[0])
if abs(pinA-pinB) != 1:
in_base = pins[0] if pinA < pinB else pins[1]
self.sm_qenc = StateMachine(sm_id, self.sm_qenc, freq=freq, in_base=in_base, out_base=in_base)
self.sm_qenc.exec("set(x, 1)") # we once decrement at the start
self.sm_qenc.exec("in_(pins, 2)")
self.sm_qenc.active(1)
@staticmethod
@rp2.asm_pio(in_shiftdir=PIO.SHIFT_LEFT, out_shiftdir=PIO.SHIFT_RIGHT)
def sm_qenc():
jmp("read") # 0000 : from 00 to 00 = no change
jmp("decr") # 0001 : from 00 to 01 = backward
jmp("incr") # 0010 : from 00 to 10 = orward
jmp("read") # 0011 : from 00 to 11 = error
jmp("incr") # 0100 : from 01 to 00 = forward
jmp("read") # 0101 : from 01 to 01 = no change
jmp("read") # 0110 : from 01 to 10 = error
jmp("decr") # 0111 : from 01 to 11 = backward
jmp("decr") # 1000 : from 10 to 00 = backward
jmp("read") # 1001 : from 10 to 01 = error
jmp("read") # 1010 : from 10 to 10 = no change
jmp("incr") # 1011 : from 10 to 11 = forward
jmp("read") # 1100 : from 11 to 00 = error
jmp("incr") # 1101 : from 11 to 01 = forward
label("decr")
jmp(x_dec, "read") # 1110 : from 11 to 10 = backward
label("read") # 1111 : from 11 to 11 = no change
mov(osr, isr) # save last pin input in OSR
mov(isr, x)
push(noblock)
out(isr, 2) # 2 right bits of OSR into ISR, all other 0
in_(pins, 2) # combined with current reading of input pins
mov(pc, isr) # jump into jump-table at addr 0
label("incr") # increment x by inverting, decrementing and inverting
mov(x, invert(x))
jmp(x_dec, "here")
label("here")
mov(x, invert(x))
jmp("read")
nop()
nop()
nop()
nop()
nop()
nop()
nop()
def read(self):
for _ in range(self.sm_qenc.rx_fifo()):
self.sm_qenc.get()
n = self.sm_qenc.get()
return n if n < (1<<31) else n - (1<<32)
pinA = Pin(15, Pin.IN, Pin.PULL_UP)
pinB = Pin(16, Pin.IN, Pin.PULL_UP)
qenc = PIO_QENC(0, (pinA, pinB))
print('starting....')
for i in range(120):
print('x:', qenc.read())
sleep_ms(500)
qenc.sm_qenc.active(0)
print('stop')
The jump is
mov(pc, isr)
Apparently the programm is not placed at address 0 by default.
First question: Is there a way in micropython to enforce that the program is placed at address 0? In PIO-code there is ".origin 0" which seems to do that.
A shorter version:
def sm_qenc():
jmp("read") # 000 : B from 0 to 0 => no change
jmp("decr") # 001 : B from 0 to 1, A = 0 => backward
jmp("read") # 010 : B from 0 to 0 => no change
jmp("incr") # 011 : B from 0 to 1, A = 1 => forward
jmp("incr") # 100 : B from 1 to 0, A = 0 => forward
jmp("read") # 101 : B from 0 to 0 => no change
label("decr")
jmp(x_dec, "read") # 110 : B from 1 to 0, A = 1 => backward
label("read") # 111 : B from 0 to 0 => no change
mov(isr, x)
push(noblock)
out(isr, 1) # right bit B' of OSR into ISR, all other 0
in_(pins, 2) # combined with current reading A B of input pins
mov(x, invert(x))
jmp(x_dec, "here")
label("here")
mov(x, invert(x)) # we rely on implicit .wrap with micropython
jmp("read")
def sm_qenc():
label("decr")
mov(isr, x)
push(noblock)
out(isr, 1) # right bit B' of OSR into ISR, all other 0; needs out_shiftdir=PIO.SHIFT_RIGHT
mov(y, isr) # use y to perform different jumps
jmp(y_dec, "next1")
label("next1")
jmp(not_y, "decr") # isr = 001 : B from 0 to 1, A = 0 => backward
jmp(y_dec, "next2")
label("next2")
jmp(y_dec, "next3")
label("next3")
jmp(not_y, "incr") # isr = 011 : B from 0 to 1, A = 1 => forward
jmp(y_dec, "next4")
label("next4")
jmp(not_y, "incr") # isr = 100 : B from 1 to 0, A = 0 => forward
jmp(y_dec, "next5")
label("next5")
jmp(y_dec, "next6")
label("next6")
jmp(not_y, "decr") # isr = 110 : B from 1 to 0, A = 1 => backward
jmp("read")
mov(x, invert(x))
jmp(x_dec, "here")
label("here")
jmp("read")
More questions:
When I print the state machine I get:
[array('H', [65, 41190, 41153, 32768, 24769, 16386, 41030, 136, 96, 138, 139, 114, 141, 114, 143, 144, 96, 1, 41001, 84, 41001, 1]), 10, -1, 86016, 524288, None, None, None]
Has anybody used
PIO.add_program(program)
Is there a way to read out the program from the PIO?
If I add two programms, how do I control which program to activate?
Does this automatically happen when I instantiate two state machines with rp2.StateMachine and PIO id.s of the same block e.g. 0 and 1?
TLDR: We now have two micropython quadrature (rotary) encoders in almost-hardware on RPI2040.
And many questions:-) Thank you for answers and hints. Raul
