stdin memory leak
aviator_11
Re: stdin memory leak
Post by aviator_11 » Wed Apr 27, 2022 7:09 pm
Thank you very much for all your advice and insight, I agree. I need to be very aware of memory usage in the functionality I choose to use, especially with strings. Circuitpython must have been releasing memory without me realizing it. And when I introduced a second thread in micropython, the increasing usage of available memory eventually caused the second thread to crash, so the problem became more obvious.
Post by Roberthh » Wed Apr 27, 2022 7:30 pm
The intended memory handling of MicroPyhton and CircuitPython are identical. MicroPython will also automatically release memory when needed. So no action is required unless you want to optimize you timing.
aviator_11
Post by aviator_11 » Wed Apr 27, 2022 9:37 pm
Do you have any suggestions on good ways to pre-allocate memory for strings or release memory used for string functions? Or is the best method to gc.collect() after I'm done decoding into a string, similar to below?
import sys
import gc
b = bytearray(1)
def read():
        sys.stdin.readinto(b)
        return b.decode('ascii')
        read()
        #gc.collect()
        print (gc.mem_free())
Post by Roberthh » Thu Apr 28, 2022 6:19 am
Please do not panic about memory handling. Unless you run into a real problem, like allocation exceptions, let the memory manager do it's work.
scruss
Post by scruss » Thu Apr 28, 2022 7:31 pm
As an aside:
decodes to UTF-8. That's all that MicroPython understands. The argument string is currently ignored
