I may have a difficulty in understanding how libraries / modules are structured or perhaps more direct the immediate challenge I face: where are the libraries advocated in the documentation when I wish to use them at a Pico ?
When I read mp 1.18 documentation, both bluetooth and network are listed under "Functionality specific to the MicroPython implementation is available in the following libraries...)"; not in the subsequent section that addresses port-specific matters.
I hope I may conclude from this that for example BT and Network are indeed available for the rp2040 port. However, when I try to access / import them, Thonny tells me it cannot find it. They are not listed either when I use the help function (mp 1.18). Just fr testing, I used also the nightly build of May 6 which I guess will soon lead to 1.19.
Any guidance pls to help me understand the trick to access and potential usage of the libraries listed under "Functionality specific ...." ?
Thx a lot,
Rob
network / BT / BLE modules for Pico ?
Re: network / BT / BLE modules for Pico ?
Hi Rob, and forum experts,
I'm strruggling with almost the same problem. I can see, that in the network library there is support for ENC28J60 ethernet interface, but network is completely missing from Micropython compiled for Pico. Should I "just" complie micropython from source for pico, and build also the network library?
Thanks,
Balazs Kovacs
Thanks,
Balazs Kovacs
