usocket/network librarie
CookieNinja
Post by CookieNinja » Mon May 16, 2022 9:02 am
Good Morning/Afternoon/Evening
So I'm rather new to the microcontroller scene, so I could easily be missing something simple. However, I'm trying to send live sensor data from my Raspberry Pi Pico, running Micropython 1.18, over my Wave Pico-ESP8266 wifi module running the latest firmware, to Firebase. I'm using Thonny with the interpreter set to MicroPython (Raspberry Pi Pico). I've been trying to get hold of the usocket and unetwork libraries as the library I'm using for Firebase uses usocket for many of the functions. So is there something I'm missing on how to get hold of the usocket library or is it module dependent?
Kind Regards
anna.marzetti
Re: usocket/network librarie
Post by anna.marzetti » Tue Jun 14, 2022 5:58 am
I am sorry I cannot help, I have the same doubt that you do, I am unable to connect Firebase to the Raspberry Pi Pico through Micropython. That is why I wanted to ask you if you were able to do so after all or if you were forced to use C or change the database?
Thank you very much!
I send you all my best wishes.
Kind regards!!
scruss
Post by scruss » Tue Jun 14, 2022 6:10 pm
... I've been trying to get hold of the usocket and unetwork libraries
They should be built in. Try
import usocket
in the REPL and see what it does.
Alternatively, try
help('modules')
in the REPL to see the libraries built in
