Here is the code that sends the file:
# send.py
import os
import serial
import struct
import sys
# serial port
port = "COM4"
# open serial
ser = serial.Serial(port, 115200)
# file name
filename = sys.argv[1]
file_size = os.path.getsize(filename)
print("File size = {} bytes.".format(file_size))
f = open(filename, "rb")
# send file size in 32 bit header
header = struct.pack('<L', file_size)
ser.write(header)
ser.flush()
# send file in chunks
chunk_size = 1024
nbytes = 0
bytes = f.read(chunk_size)
nbytes += len(bytes)
if not bytes:
print("done, break.")
break
ser.write(bytes)
ser.flush()
print("wrote {} bytes...".format(nbytes))
except Exception as e:
print(e)
print("closing...")
ser.close()
f.close()
import sys
import os
import struct
# 2 - esp32, 25, pico
PIN_LED = 25
def blink(pin_led, nblink):
for i in range(nblink):
pin_led.value(1)
time.sleep(0.25)
pin_led.value(0)
time.sleep(0.25)
def main():
# set up LED
pin_led = Pin(PIN_LED, Pin.OUT)
pin_led.value(0)
f = open("recv.bin", "wb")
# get file size in 4 byte header
header = sys.stdin.buffer.read(4)
#print(header)
file_size = struct.unpack('<L', header)[0]
# get rest of the data
chunk_size = 1024
n_chunks = file_size // chunk_size
remaining = file_size - (n_chunks * chunk_size)
blink(pin_led, 2)
# create byte array and manage memory
ba = bytearray(chunk_size)
nbytes = 0
for i in range(n_chunks):
data = sys.stdin.buffer.read(chunk_size)
f.write(data)
# get remaining bytes < chunk_size
data = sys.stdin.buffer.read(remaining)
f.write(data)
# not reached
blink(pin_led, 4)
pin_led.value(1)
# close file
f.close()
if __name__ == "__main__":
main()
If I create a file as below, the data goes through fine:
>>> f = open("104090a.bin", "wb")
>>> data = bytearray(b'a'*104090)
>>> f.write(data)
104090
>>> f.close()
>>> import numpy as np
>>> f = open("104090r.bin", "wb")
>>> data = bytearray(np.random.bytes(104090))
>>> f.write(data)
104090
>>> f.close()
Why does it get stuck?
I am guessing it has to with the encoding, or I must be messing something else up. Any suggestions appreciated. Thanks!
