Is it possible to have two serial ports open on the Pico with one USB connection?
When I plug in the RP2040 Pico via USB, I want to see two serial ports that I can communicate with. One will be used to communicate with the Pico, and the other will be used as a serial passthrough for a second device connected to the Pico. I'd appreciate any suggestions on how to go about implementing this using MicroPython. Thanks!
Re: Is it possible to have two serial ports open on the Pico with one USB connection?
Hi
Sorry for the late answer. Maybe you've already found the answer. If not, here's a pointer to the solution:
This is possible, but not without making your own version of MicroPython. Fortunately others had the same question before you (not me!).
I've found this interesting link for you:
https://forums.raspberrypi.com/viewtopi ... 2#p1979332
Good luck!
Good luck!
Thanks, Filip. I might as well as drop to C for implementing this. I found that TinyUSB has a dual CDC port example:
https://github.com/hathach/tinyusb/tree ... dual_ports
What about the examples using the PIO to implement a UART? See this link.
That's an option indeed if you don't need the rest of the features you get using MicroPython
electronut wrote: ↑Wed Jun 15, 2022 2:45 amThanks, Filip. I might as well as drop to C for implementing this. I found that TinyUSB has a dual CDC port example:
Hi Peter, the question was to have two virtual (CDC) serial ports on one USB connection, don't see how you can do that using PIO
pythoncoder wrote: ↑Wed Jun 15, 2022 9:45 amWhat about the examples using the PIO to implement a UART? See this link.
Ah, sorry. I didn't even know that such a thing was possible.
