I'm struggling with the internals of the UART IRQ ringbuffer mechanism (I guess)
In my project; the RPi PICO is connected to a Waveshare Pico-SIM7020X-NB-IoT (modem for NB-IoT) through serial port 0.
Unfortunately this hardware setup does not offer hardware flow control.
Communication between modem and PICO is through AT commands, quite standard.
I created the UART instance with "large" buffers inside my communication class:
self.uart = machine.UART(0, 115200, tx=Pin(0), rx=Pin(1), bits=8, parity=None, stop=1, rxbuf=2000, txbuf=1000)
I have two different methods for reading data: a 'dumb' one that just waits a long time and a second (more intelligent?) one that should only wait until a certain expected response has been received (+\r\n). This method also sends the AT command first to the modem. Because sometimes more data is sent by the modem than what we need, the remainder of the data remains in the rxbuffer (that's why I purge the read buffer before I proceed to sending the 'next' AT command).
Method one ("dumb"):
def waitResp(self, timeout=2000):
prvMills = ticks_ms()
resp = b""
while ticks_diff(ticks_ms(),prvMills) < timeout:
if self.uart.any():
resp = b"".join([resp, self.uart.read(1)])
return self.safe_decode(resp,"waitResp")
def sendCMD_waitSpecificResponse(self, cmd, timeout=2000, responseList = ["OK","ERROR"]):
resp = b""
decodedString = ""
responseFromListReceived = False
#purge buffer
while self.uart.any() : self.uart.read(1)
self.uart.write((cmd + '\r\n').encode()))
while (ticks_diff(ticks_ms(),prvMills) < timeout) and not responseFromListReceived:
if self.uart.any():
resp = b"".join([resp, self.uart.read()])
decodedString = self.safe_decode(resp,"sendCMD_waitSpecificResponse")
for expectedResponse in responseList:
if decodedString.rfind(expectedResponse) > 0:
if decodedString.rfind(expectedResponse) < decodedString.rfind("\r\n"):
responseFromListReceived = True
startExpectedResponse = decodedString.rfind(expectedResponse)
endExpectedResponse = decodedString.find("\r\n",startExpectedResponse)
return decodedString[startExpectedResponse:endExpectedResponse]
#only getting here in case of a time-out
return ""
def safe_decode(self,instr, call_reference):
return instr.decode()
except Exception as e:
self.log.error("Exception while decoding binary string \"" + repr(e) + " in : " + call_reference)
return ""
BUT... when I use my smart method on long messages, things go wrong: I'm not able to receive all data, the method exits with a time-out. Debugging showed me that at a certain moment, no more data is available (uart.any() = 0), but I'm sure I didn't receive all.
I guess there is a maybe a FIFO buffer overrun in the PICO hardware, but I presumed that because the reading of the PICO UART FIFO is done by the uart_service_interrupt routine, I wouldn't loose data...
Example data received just waiting 10 seconds with the "dumb" method:
AT+CENG?\r\r\n+CENG: 6151,3,240,"0175C3C9",-101,-12,-88,0,20,"4661",0,,-90\r\n+CENG: 6151,3,289,-102\r\n+CENG: 6151,3,501,-104\r\n+CENG: 6151,3,251,-107\r\n\r\nOK\r\n
Using method two, I only get to receive:
AT+CENG?\r\r\n+CENG: 6151,3,273,"0175A8C9",-
I find this very annoying, because I made this second method mainly for gaining time with the AT commands that produce longer answers. As they tend to take a while before the first character arrives, I now need to put in very long time-outs to be sure to have received all... Receiving all means (mostly) that the answer ends with an "OK" or "ERROR", so I guess the "smart" method was likely to be the good solution for my problem. But as stated above: I tend not to receive all when checking whether I received all...
Am I missing something
