I'm getting the following output on arduino nano rp2040 connect.
>>> webrepl.start()
File "webrepl.py", line 74, in start
File "webrepl.py", line 16, in setup_conn
OSError: no available NIC
Any ideas?
Webrepl on Arduino nano rp2040 connect
Re: Webrepl on Arduino nano rp2040 connect
Did you start WiFi at the board first?
I get the following output on running wireless AP.
>>> import network
>>> wlan=network.WLAN(network.AP_IF)
>>> wlan.active(True)
>>> wlan.config(essid="android123",key="connect",security=wlan.WEP,channel=2)
OSError: failed to start in AP mode
Thanks,
>>> import network
>>> wlan.active(True)
Thanks,
Setting up wireless ap before running webrepl.start() solved the issue.
Thanks,
Thanks,
