Hello!
What is the most appropriate firmware to program a RP2040 Zero board?
https://www.waveshare.com/wiki/RP2040-Zero
Maybe the PIMORONI TINY2040 which also has 2 MB of Flash, or the RASPBERRY PICO firmware?
Is there any difference between them?
Thankfully,
Ernesto.
Firmware for RP2040 Zero
Re: Firmware for RP2040 Zero
Ideally a board definition should be written, but yeah like you say, any firmware for a board with 2MiB flash will work, including the two you mentioned.
Thank you!
I'm using the PICO firmware and works OK.
Regards,
Ernesto.
Regards,
Ernesto.
