How to distinguish Pico from Pico W?
Posted: Thu Jul 07, 2022 5:13 am
by aivarannamaa
I haven't received my Pico W yet, but I'm told that that its INFO_UF2.TXT uses same Model and Board-ID values as original Pico. Do you know why is that?
Is there another way for distinguishing Pico W from original Pico in bootloader mode? I'd like to enhance Thonny's MicroPython installation dialog to pre-select proper MicroPython automatically.
What about USB PID/VID in normal mode? Are they same as on original Pico?
Re: How to distinguish Pico from Pico W?
Posted: Thu Jul 07, 2022 8:00 am
by jimmo
aivarannamaa wrote: ↑Thu Jul 07, 2022 5:13 am
I don't have one yet either, but they're the same RP2040 chip -- the bootloader doesn't know anything about what else is on the board, and the bootloader on the RP2040 is in ROM.
I believe they would be the same because MicroPython doesn't override it on these boards (again, haven't checked, but I can't see how it would be different from the code). We possibly could though -- might be worth raising an issue on github.com/micropython/micropthon and @kilograham
Posted: Thu Jul 07, 2022 2:37 pm
by scruss
There's a slightly messy method here:
with some additional commentary in that thread. There's also an official method on page 25 of the "
Connecting to the Internet" datasheet.
I haven't got a Pico W yet either, and it looks like mine are a week or more away
Posted: Thu Jul 07, 2022 3:38 pm
by Shards
I have a couple of the new chips, available from day one here in the UK. I can confirm the INFO_UF2.TXT file is identical to the original board. Once micropython is installed it's easy enough to identify the new board. If nothing else it has a network module.
Posted: Thu Jul 07, 2022 10:24 pm
by danjperron
OK I got both of them .
you could search for the term "Pico" and "Pico W" to figure out which firmware is for. Mostly check for "Pico W"
pi@benchpi4:~/micropython/ports/rp2 $ grep -obUa "Pico " ./build-PICO/firmware.uf2
496680:Pico
pi@benchpi4:~/micropython/ports/rp2 $ grep -obUa "Pico " ./build-PICO_W/firmware.uf2
757446:Pico
pi@benchpi4:~/micropython/ports/rp2 $ grep -obUa "Pico W" ./build-PICO/firmware.uf2
pi@benchpi4:~/micropython/ports/rp2 $ grep -obUa "Pico W" ./build-PICO_W/firmware.uf2
757446:Pico W
Posted: Wed Jul 13, 2022 8:32 pm
by scruss
I did find a difference, but I'm not sure it's relevant. INDEX.HTM on a v1 silicon Raspberry Pi Pico includes the string
version=E0C912952D54, but on a (v2 silicon) Pico W it's
version=E0C9125B0D9B.
I don't have any other v2 silicon RP2040 boards to test whether the version relates to the silicon or something else. Other v1 silicon RP2040 boards contain E0C912952D54, so I'm not very hopeful that it can detect Pico Ws. It can certainly tell you if it's
not a Pico W, though ...
Posted: Wed Jul 13, 2022 9:49 pm
by aivarannamaa
Thanks for sharing this observation! But I think I'll refactor the installation dialog to present a dropdown with MicroPython variants rather than rely on index.htm
