problem port .... :(
iceelon
Post by iceelon » Tue Jul 12, 2022 11:52 am
Hi !!
first of all, thank you...
Some time ago I saw a code in gist of a Des3
I have basic level knowledge in python but I encounter the following problem in this line :
                if _pythonMajorVersion < 3:
			return ''.join(result)
			return bytes.fromhex('').join(result)
Reason: Add [code] formatting
Re: problem port .... :(
Post by jimmo » Tue Jul 12, 2022 12:19 pm
bytes.fromhex('')
MicroPython doesn't support bytes.fromhex
I think it should be added -- see the PR I raised here: https://github.com/micropython/micropython/pull/7539
What is the code actually trying to do though? MicroPython is also only Python 3, so you don't need the if statement. I feel like the whole thing should just be
return b''.join(result)
iceelon
Post by iceelon » Tue Jul 12, 2022 1:06 pm
thanks, it works !!!!
			return ubinascii.unhexlify('').join(result)
Post by jimmo » Tue Jul 12, 2022 1:28 pm
is exactly the same as just writing
b''
iceelon
Post by iceelon » Tue Jul 12, 2022 6:06 pm
ummm not :(
show this error
TypeError: join expects a list of str/bytes objects consistent with self object
oo sorry ...
work
