Setting hostname on Pico W
cubbieco
Re: Setting hostname on Pico W
Post by cubbieco » Sun Sep 04, 2022 11:46 pm
I've successfully compiled Micropython for the Pico W so I have things set up right. How do I do the compile flag to use the drivers/cyw43 version so I can set the hostname? It might not compile yet but I'd like to try.
Post by jimmo » Mon Sep 05, 2022 1:18 am
This isn't supported yet. Making this work that way isn't worth the trouble. Instead three things need to happen:
- The "public" version of the cyw43 driver (the one lib/cyw43-driver) in needs to be updated with the new features.
- The other ports using the existing one in drivers need to be updated to use the lib one.
- The compile-time macros to switch between the two need to be removed (making all features available).
Most of this is pretty close to being done, there's just a lot of stuff in the review queue at the moment.
cubbieco
Post by cubbieco » Mon Sep 05, 2022 1:50 am
Thank you for your reply. I'll just be patient then. :D
