I'm a beginner with microcontrollers, my first project is simply to hook up a pt100 temperature sensor to my Pico to make a PID controller. I've managed to do this using circuit python and it works great but when I tried with micropython i keep getting a bad pin error. Have not been able to resolve this. The code below is a modified version of the adafruit Max31865 amplifier example code which is supplied with circuit python in mind.
Please see below for answer to "why not just use circuit python then?"
"""Simple demo of the MAX31865 thermocouple amplifier.
Will print the temperature every second."""
import adafruit_max31865
CS = machine.Pin(22, machine.Pin.OUT)
# Initialize SPI bus and sensor.
SPI = machine.SPI(0, sck=machine.Pin(24, machine.Pin.OUT),
mosi=machine.Pin(25, machine.Pin.OUT),
miso=machine.Pin(21,machine.Pin.OUT)#<-----"bad SCK pin" error originates here
SPI.init(baudrate=115200, polarity=0, phase=1)
#SENSOR = adafruit_max31865.MAX31865(SPI, CS)
# Note you can optionally provide the thermocouple RTD nominal, the reference
# resistance, and the number of wires for the sensor (2 the default, 3, or 4)
# with keyword args:
sensor = adafruit_max31865.MAX31865(spi, cs, rtd_nominal=100, ref_resistor=430.0, wires=3)
# Main loop to print the temperature every second.
# Read temperature.
TEMP = SENSOR.temperature
# Print the value.
print("Temperature: {0:0.3f}C".format(TEMP))
# Delay for a second.
time.sleep(1.0)
File "<stdin>", line 13, in <module>
ValueError: bad SCK pin
As to why use micro python in the first place if circuit python works - I need to measure the temperature and then calculate a PID value and then send this value to a SSR, but with circuit python I understand you can't run multithreaded operations (unlike micropython) therefore the following is happening
read temperature
calculate PID
tell SSR to turn on/off at given frequency
SSR then turns off whilst a new PID is calculated
If anyone can give me a hint on how to have the SSR still turn on/off uninterrupted whilst calculating a new frequency value in circuit python that would help too.
Many thanks for reading, any help will be really appreciated.
Regards
Jon
