Unable to blink unboard LED. (Pico and MicroPython)
Hi. I'm just bought an Raspberry Pi Pico and the get started book. I have some issues when it comes to using the machine module. When following the books guide on how to make the onboard LED (GP25) blink, it does not work. However I tried and followed another guide using the picozero extension and then everything works. Why can't I use the machine module?
Re: Unable to blink unboard LED. (Pico and MicroPython)
The shown example works causing slow blinking: 5 seconds on/5 seconds off.
Well the code should work but for some reason the LED does not light up. I've tried to let the code run for 10 minutes and nothing happens. I've also removed everything from the loop and just had:
led_onboard.value(1)
And it works with the picozero extension? Are you sure that you use a raspberry Pi Pico 2040? https://www.raspberrypi.com/products/raspberry-pi-pico/
Yes it works with picozero. Yeah well it should be the Pi Pico W 2040, I've bought it from here. https://www.electrokit.com/produkt/raspberry-pi-pico-w/Roberthh wrote: ↑Sun Jul 31, 2022 3:42 pmAnd it works with the picozero extension? Are you sure that you use a raspberry Pi Pico 2040? https://www.raspberrypi.com/products/raspberry-pi-pico/
I continued in the book and connect an external LED to pin 15 and this works perfect even with the machine module. The same code but I just changed the pin. Guess I can live without using the onboard LED, but I still think it's very strange.
On the Pico W you need to use rather than
led = Pin('LED', Pin.OUT)
led = Pin(25, Pin.OUT)
Thanks a lot guys for the quick response! Didn't know it was different on the Pico W, but not it works
