Connect pico to wifi without password
jensenrobert
Post by jensenrobert » Wed Aug 03, 2022 7:52 pm
Hi
At my university, we have a dedicated iot-network for various sensors and micro-controllers to connect to. This network is protected only by a white-list and uses an empty password. I have several devices connected to this network, including M5-stacks and a Pi 3, with no problems.
However, the Pico W seems to have a problem with the empty password. I can scan the network with no problems:
wlan.scan()
[.... (b'device', b'\x00,\xc8\x87\r@', 11, -77, 0, 1),
(b'eduroam', b'\x00,\xc8\x87\x0ba', 11, -84, 5, 2),
(b'device', b'\x00,\xc8\x87\x0b`', 11, -86, 0, 1),
But when I try to connect, I get this error:
wlan.connect('device')
OSError: [Errno 1] EPERM
Also, using an empty string as password gives same result:
wlan.connect('device', '')
I can connect the same unit to my home network without problems, so I am fairly sure the Pico works (also, I have confirmed this on two units).
Any suggestions as to what I can do to get around this?
Best regards
Robert
fdufnews
Re: Connect pico to wifi without password
Post by fdufnews » Thu Aug 04, 2022 4:31 pm
In the MicroPython doc it is declared this way
WLAN.connect(ssid=None, key=None, *, bssid=None)
Connect to the specified wireless network, using the specified key. If bssid is given then the connection will be
restricted to the access-point with that MAC address (the ssid must also be specified in this case).
Have you tried key=None
jensenrobert
Post by jensenrobert » Fri Aug 05, 2022 4:34 am
Yes, this unfortunately gives the same result :(
muka
Post by muka » Sun Aug 07, 2022 2:24 pm
I have the same problem? Any progress?
davesaldub
Post by davesaldub » Thu Aug 18, 2022 1:55 pm
I also have the same issue.
Post by jimmo » Thu Aug 18, 2022 2:25 pm
Does the network have no security (i.e. open), or does it have an empty key?
You need to use
connect("network", security=0)
if it's an open network.
and
connect("network", key="")
if it's an empty key.
I think... It's also possible this is a bug with the Pico W. Can you try both and let me know.
davesaldub
Post by davesaldub » Thu Aug 18, 2022 2:29 pm
The network has no security, but I tried both just to be sure and I still got the same error.
Post by jimmo » Thu Aug 18, 2022 11:49 pm
OK thanks. Looks like there's already an issue tracking this -- https://github.com/micropython/micropython/issues/9016
