sgp30 not found [resolved]
iceelon
Post by iceelon » Sun Aug 21, 2022 9:31 am
hello again ...
trying to put an sgp30 into operation for measurement...
  File "<stdin>", line 22, in <module>
  File "/lib/spg301.py", line 70, in __init__
RuntimeError: SGP30 Not detected
I think it's on this line
 featureset = self._i2c_read_words_from_cmd([0x20, 0x2f], 0.01, 1)
        if featureset[0] != _SGP30_FEATURESET:
            raise RuntimeError('SGP30 Not detected')
        self.iaq_init()
scruss
Re: sgp30 not found
Post by scruss » Sun Aug 21, 2022 7:16 pm
what's your wiring?
does I2C.scan() see the device?
iceelon
Re: sgp30 not found
Post by iceelon » Mon Aug 22, 2022 8:33 am
hello
If everything is correct, it is well connected, it detects the device... but nothing continues to give an error in that part... I downloaded the documentation of the sensor to see if I can see where to go...
karfas
Re: sgp30 not found
Post by karfas » Mon Aug 22, 2022 1:21 pm
This makes no sense at all for me. "If everything is correct, it works" - yes, we all assume that. :shock:
But DOES it work ? Do you get the correct address from i2c.scan() ?
When "nothing" gives you an error, there is no error at all ;)
Serious: What do you get back in featureset[0] ? Maybe you got a slightly different SGP30 sensor.
What do you expect to get back (according to the datasheet) ?
A few hours of debugging might save you from minutes of reading the documentation! :D
iceelon
Re: sgp30 not found
Post by iceelon » Tue Aug 23, 2022 8:51 am
hello
The library expects a value of 0x20 exactly but sensor returns 0x22 which would indicate “better” featureset than what’s required.
it works now....
