Pico W: Problem binding a socket to a UDP Multicast Group
Beormund
Post by Beormund » Wed Aug 24, 2022 11:38 am
I'm trying to get uPyEcho (Wemo emulator for Alexa discovery) to work on Pico W. I'm connected to wifi and MQTT using the async mqtt module. The following code is supposed to bind the socket to th UDP Multicast group ("239.255.255.250", 1900) which is what Alexa uses to discover Wemo devices. But I only receive broadcasts with a destination group ("255.255.255.255", 1900). I've checked my network using WireShark and Alexa is broadcasting discovery messages to 239.255.255.250. Any suggestions on how to resolve please?
    def inet_aton(self, addr):
        ip_as_bytes = bytes(map(int, addr.split(".")))
        return ip_as_bytes
    async def init_socket(self):
        ok = True
        self.ip = "239.255.255.250"
        self.port = 1900
            # This is needed to join a multicast group
            self.mreq = struct.pack("4sl", self.inet_aton(self.ip), 0)
            # Set up server socket
            self.ssock = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
            self.ssock.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
                self.ssock.bind((self.ip, self.port)) # Also tried ("", self.port)
            except Exception as e:
                dbg("WARNING: Failed to bind %s:%d: %s", (self.ip, self.port, e))
                ok = False
                self.ssock.setsockopt(socket.IPPROTO_IP, socket.IP_ADD_MEMBERSHIP, self.mreq)
                dbg("WARNING: Failed to join multicast group!: " + str(e))
                ok = False
            dbg("Failed to initialize UPnP sockets!")
            return False
        if ok:
            dbg("Listening for UPnP broadcasts")
Beormund
Re: Pico W: Problem binding a socket to a UDP Multicast Group
Post by Beormund » Wed Aug 24, 2022 12:44 pm
I suspect there is a bug preventing the socket joining a UDP multicast group
# self.mreq = b'\xef\xff\xff\xfa\x00\x00\x00\x00'
Beormund
Post by Beormund » Wed Aug 24, 2022 3:41 pm
Here's a stripped down test case for listening to UDP multicast broadcasts on 239.255.255.250:1900:
# wlan access
SSID = '<ROUTER>'
WPA2_PASS = "<PASSWORD>"
ssid_ = SSID
wpa2_pass = WPA2_PASS
def do_connect():
    if not sta_if.isconnected():
        print("connecting to network...")
        sta_if.active(True)
        sta_if.connect(ssid_, wpa2_pass)
        while not sta_if.isconnected():
            pass
    print("network config:", sta_if.ifconfig())
do_connect()
import socket
    from socket import sockaddr
except:
    sockaddr = lambda x: x
def inet_aton(addr):
    return ip_as_bytes
UPNP_MCAST_IP = "239.255.255.250"
UPNP_PORT = 1900
BIND_IP = "0.0.0.0"
REUSE_SOCKET = 0
serv_sock = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
addr = socket.getaddrinfo(BIND_IP, UPNP_PORT, socket.AF_INET, socket.SOCK_DGRAM)[0][4]
serv_sock.bind(addr)
serv_sock.setsockopt(socket.IPPROTO_IP, socket.IP_ADD_MEMBERSHIP, inet_aton(UPNP_MCAST_IP) + inet_aton(BIND_IP));
if REUSE_SOCKET:
    resp_sock = serv_sock
    resp_sock = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
    data, addr = resp_sock.recvfrom(1024)
    if data.startswith(b"M-SEARCH"):
        print("From: ", sockaddr(addr))
        print(data)
This should publish quite a bit of udp broadcasting but doesn't on the pico w. If you have Alexa: "Alexa, discover devices..."
MicroPython firmware: rp2-pico-w-20220824-unstable-v1.19.1-316-g8139cbcf6.uf2
Post by jimmo » Thu Aug 25, 2022 2:03 pm
Thanks for the detailed info and repro!
I have a working example (running in CPython) than can pick up the SDDP multicasts on my network, but also unable to get this working on my Pico W.
It also works fine on an ESP32, so I think there's definitely a bug here. I have raised https://github.com/micropython/micropython/issues/9105 to track, please see updates there.
Post by jimmo » Fri Aug 26, 2022 2:06 pm
Thanks again for raising this. I've submitted a PR to fix the wifi driver.
Beormund
Post by Beormund » Sun Aug 28, 2022 3:45 pm
Cheers jimmo
Beormund
Post by Beormund » Tue Sep 20, 2022 9:11 am
The PR doesn't appear to have been approved upstream. Would it be possible to fork the driver, incorporate the fix locally and re-sync later?
Post by jimmo » Tue Sep 20, 2022 10:23 pm
Yes, absolutely.
No fork necessary, just fetch the PR into the lib/cyw43-driver submodule. (cd lib/cyw43-driver: git fetch origin pull/25/head:multicast-register; git checkout multicast-register)
