thanks for the tip Dave. It does have an except block, however I dont have enough experience in python especially with the server stuff.
import rp2
import ubinascii
import urequests as requests
from secrets import secrets
import socket
from neopixel import Neopixel
from neo_sweep import color_chase
from fixed_colors import fixed_color
from stop_neopixel import stop_all
# Set country to avoid possible errors
rp2.country('NL')
wlan.active(True)
# If you need to disable powersaving mode
wlan.config(pm = 0xa11140)
# See the MAC address in the wireless chip OTP
mac = ubinascii.hexlify(network.WLAN().config('mac'),':').decode()
print('mac = ' + mac)
# Load login data from different file for safety reasons
ssid = secrets['ssid']
pw = secrets['pw']
wlan.connect(ssid, pw)
# Wait for connection with 10 second timeout
timeout = 10
while timeout > 0:
if wlan.status() < 0 or wlan.status() >= 3:
break
timeout -= 1
print('Waiting for connection...')
time.sleep(1)
# Define blinking function for onboard LED to indicate error codes
def blink_onboard_led(num_blinks):
led = machine.Pin('LED', machine.Pin.OUT)
for i in range(num_blinks):
led.on()
time.sleep(.2)
led.off()
time.sleep(.2)
wlan_status = wlan.status()
blink_onboard_led(wlan_status)
if wlan_status != 3:
raise RuntimeError('Wi-Fi connection failed')
print('Connected')
status = wlan.ifconfig()
print('ip = ' + status[0])
# HTTP server with socket
addr = socket.getaddrinfo('0.0.0.0', 80)[0][-1]
s = socket.socket()
s.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
s.bind(addr)
s.listen(1)
print('Listening on', addr)
numpix = 30
brightness = 125
currentMode = 'off'
ledStatus = 'off'
# Listen for connections
cl, addr = s.accept()
print('Client connected from', addr)
r = cl.recv(1024)
r = str(r)
print('request', r)
if r.find('update') > -1:
cl.send('HTTP/1.0 200 OK\r\nContent-type: application/json\r\nAccess-Control-Allow-Origin: *\r\n\r\n')
#cl.send(ledStatus)
cl.send('{"numpix":' + str(numpix) + ','+ '"currentMode":'+ '"'+str(currentMode)+'"' + ',' +'"brightness":'+ str(brightness) +'}')
print('from update', ledStatus)
print('{"ledStatus":' + str(numpix) + ','+ '"currentMode":"'+ str(ledStatus) +'"}')
#print('{"currentMode":' + str(currentMode) +',' + '"numpix":'+ str(numpix) +'}')
cl.close()
time.sleep(0.1)
#adjust number of pixels if requested
if r.find('numpix') > -1:
pixelnum = r[r.index('numpix=') + len('numpix='):-1]
numpix = int(pixelnum)
cl.send('{"ledStatus":' + pixelnum + '}')
cl.close()
print('{"ledStatus":' + pixelnum + '}')
time.sleep(0.1)
if r.find('brightness') > -1:
brightness = r[r.index('brightness=')+ len('brightness='):-1]
brightness = int(brightness)
print(brightness)
#stop_all()
strip.brightness(int(brightness))
strip.show()
cl.send('{"ledStatus":' + '"brightness"}')
cl.close()
strip = Neopixel(numpix, 0, 10, "GRB")
strip.brightness(brightness)
brown = strip.colorHSV(165, 42, 42)
orange = strip.colorHSV(255, 165, 0)
pink = strip.colorHSV(255, 192, 203)
yellow = strip.colorHSV(255, 255, 0)
purple = strip.colorHSV(128, 0, 128)
red = strip.colorHSV(0,255,122)
green = strip.colorHSV(21845, 255, 122)
blue = strip.colorHSV(43691, 255, 122)
time.sleep(0.1)
#Turn OFF all pixels
if r.find('ledStatus=off') > -1:
currentMode = 'off'
status = 'Off'
print('LED OFF')
led.value(0)
ledStatus = '{"ledStatus": "Off"}'
cl.send(ledStatus)
cl.close()
stop_all()
time.sleep(0.1)
#CHASE mode
if r.find('ledStatus=chase') > -1:
currentMode = 'chase'
stop_all()
status = 'on'
print('LED ON')
led.value(1)
ledStatus = '{"ledStatus": "chase"}'
cl.send(ledStatus)
cl.close()
#color_chase(strip, red, blue, 0.1, numpix)
while currentMode is 'chase':
if currentMode is not 'chase':
break
for i in range(numpix):
strip.set_pixel(i-1, (0,0,0))
strip.set_pixel(i, blue)
strip.show()
time.sleep(0.1)
time.sleep(0.1)
for j in range(numpix - 1, -1,-1):
if j < (numpix -1):
strip.set_pixel(j+1, (0,0,0))
strip.set_pixel(j, red)
strip.show()
time.sleep(0.1)
time.sleep(0.1)
if r.find('ledStatus=section') > -1:
unSplitted = r.split('section&')[1].split(',')
startIndex = int(unSplitted[0])
endIndex = int(unSplitted[1])
color = unSplitted[2].split('-')
print(color)
hue = color[0]
sat = color[1]
val = color[2][:-1]
color = strip.colorHSV(int(hue),int(sat),int(val))
#strip.fill(color)
strip.set_pixel_line(startIndex, endIndex, (int(hue),int(sat),int(val)))
strip.show()
print(color)
time.sleep(0.1)
#currentMode = '{"ledStatus":' + '"fixedColor"' + ','+ '"r":' + str(red) + ','+ '"g":'+ str(green) + "," + '"b":' + str(blue) + '}'
if r.find('line-gradient') > -1:
currentMode = 'line-gradient'
stop_all()
strip.set_pixel_line_gradient(0, (numpix - 1), blue, red)
strip.show()
cl.send('{"ledStatus":' + '"line-gradient"}')
cl.close()
#fixedcolor test
if r.find('fixed_color') > -1:
stop_all()
rgb = r.split('fixed_color&')[1].split(',')
print(rgb)
red = rgb[0]
red = int(red)
green = rgb[1]
green = int(green)
print(green)
blue = rgb[2]
blue = blue[:-1]
print(blue)
blue = int(blue)
currentMode= 'fixed'
cl.send('{"ledStatus":' + '"fixedColor"' + ','+ '"r":' + str(red) + ','+ '"g":'+ str(green) + "," + '"b":' + str(blue) + '}')
cl.close()
ledStatus = '{"ledStatus": "fixed"}'
fixed_color(strip, red,green,blue)
print('test fixed color')
print('{"ledStatus":' + str(red) + ','+ str(green)+ ',' + str(blue) + '}')
time.sleep(0.1)
#response = get_html('index.html')
#cl.send('HTTP/1.0 200 OK\r\nContent-type: application/json\r\n')
#cl.send('HTTP/1.0 200 OK\r\nContent-type: application/json\r\nAccess-Control-Allow-Origin: *\r\n\r\n')
#cl.send(ledStatus)
print(ledStatus)
#cl.close()
except OSError as e:
cl.close()
print('Connection closed')
