@rp2.asm_pio()
superace
@rp2.asm_pio()
Post by superace » Wed Aug 24, 2022 12:54 pm
Either I am doing something illegal or I just do not get it.
MicroPython v1.19.1 on 2022-06-18; Raspberry Pi Pico with RP2040
Thonny
How come this code prints in REPL
inside
inside
import rp2
@rp2.asm_pio(set_init=rp2.PIO.OUT_LOW)
def blink_1hz():
    print ("inside")
    # Cycles: 1 + 7 + 32 * (30 + 1) = 1000
    set(pins, 1)
    set(x, 31)                  [6]
    label("delay_high")
    nop()                       [29]
    jmp(x_dec, "delay_high")
    set(pins, 0)
    set(x, 31)                  [6]
    label("delay_low")
    nop()                       [29]
    jmp(x_dec, "delay_low")
# Create and start a StateMachine with blink_1hz, outputting on Pin(25)
#sm = rp2.StateMachine(0, blink_1hz, freq=2000, set_base=Pin(25))
#sm.active(1)
As you see the last 2 rows are commented out so I do not get why the blink_1hz function is run... So I would expect no printed output at all, and why do I get 2 rows?
TheSilverBullet
Re: @rp2.asm_pio()
Post by TheSilverBullet » Wed Aug 24, 2022 1:32 pm
import rp2
@rp2.asm_pio()
def whatever():
    print('Cough … decorator.')
    print('Cough … closure.')
Re: @rp2.asm_pio()
Post by jimmo » Wed Aug 24, 2022 1:56 pm
There's quite a lot of magic in how the rp2.asm_pio decorator works. The summary is that it executes your function, providing it with a scope that includes functions like "set", "label", etc. And when your code calls those functions it emits the corresponding machine code (which can then be loaded into a given state machine).
(In other words -- the PIO doesn't execute your Python function. Rather the asm_pio decorator executes your function immediately as teh decorator is applied, and that's why the print statements run straight away).
See https://github.com/micropython/micropyt ... p2.py#L235 for the implementation.
TheSilverBullet: I think you're alluding to the same thing... can't quite tell though.
TheSilverBullet
Re: @rp2.asm_pio()
Post by TheSilverBullet » Wed Aug 24, 2022 1:59 pm
Yeah, I have to admit, it was a bit cryptic.
Food for thought, helps the discovery and learning process …
hippy
Re: @rp2.asm_pio()
Post by hippy » Tue Aug 30, 2022 5:44 pm
And, because it's a two pass assembler, executes it twice, causing the 'print' within it to be executed twice.
This is a simplified CPython program equivalent of the RP2 assembler which can be run at a command line to illustrate what's going on ...
emit = []
def nop   ()     : emit.append("nop")
def label (name) : emit.append(name + ":")
def jmp   (name) : emit.append("jmp " + name)
def asm_pio(**kw):
  def inner(func):
    global emit
    emit = []; func()
    emit = []; func()
    return emit
  return inner
@asm_pio()
def MyAsm():
  print("--Inside MyAsm--")
  label("loop")
  nop()
  jmp("loop")
# print("Executable PIO code is : {}".format(MyAsm))
Note that the two 'func()' calls within 'inner' are what executes your 'MyAsm' routine twice, causing the "--Inside MyAsm--" to be printed twice, even with the 'print' commented out.
Re: @rp2.asm_pio()
Post by jimmo » Tue Aug 30, 2022 11:37 pm
Yes good point!
Good example with the demo version... when we get around to writing more docs about it, then that would probably be a worthwhile thing to add!
hippy
Re: @rp2.asm_pio()
Post by hippy » Wed Aug 31, 2022 12:52 pm
My view is that RP2.py needs to be nuked from orbit and completely rewritten to allow specification of free-form PIO assembler, viz -
@rp2.asm_pio()
def MyAsm():
  start: nop
         jmp  start
I'd be even more happier with having StateMachine do the assembly -
MyAsm = """
  start: nop
         jmp  start
sm = StateMachine(0, MyAsm)
I appreciate backwards compatibility is an issue but it is possible to support all of the above and retain backwards compatibility.
Even if we simply stick with what we have I believe it still needs nuking, or at least a very significant rewrite, to allow error checking to prevent things like 'set(x, 255)' and 'mov(x, 255)' mistakes and many others.
Re: @rp2.asm_pio()
Post by jimmo » Thu Sep 01, 2022 2:29 am
I think partly this was to make the PIO look similar tot he existing @asm_thumb feature in MicroPython. At the end of the day, much of this is about using the existing lexer+parser that we have for Python.
Isn't this mostly just a matter of adding more argument checking to the set() and mov() functions? Why does that require a significant rewrite? (I didn't write rp2.py and haven't had much experience with it, so this may be a silly question).
hippy
Re: @rp2.asm_pio()
Post by hippy » Thu Sep 01, 2022 10:35 am
Better argument checking is what's needed, but that requires being able to determine that named constants were used where they should have been used and not where they shouldn't be used. That's hard because, by the time the arguments pass to the code generating functions, they have all been converted to integers so those routines can't tell if they were named or not.
For example 'set(x, null)' and 'mov(x, 3)' are both accepted but neither do what the person writing those presumably expected.
My view is that error checking should catch all mistakes to protect the coder from themselves. To achieve that myself I defined named constants as a class type rather then integer so I could check they were names of registers and then check if valid for the specific command. That wasn't overly complicated but did require quite a number of changes.
Other reasons for rewriting would be to make it single pass with fixups, and to support things like 'dec(x)' and 'inc(x)' which currently require 'jmp' to a following label to be specified. What the SDK assembler accepts has been tightened up but the MicroPython RP2 hasn't kept up so now accepts things the SDK won't.
I got most of this working as proof of concept but it needs completing and a rewrite to make it production quality, and also needs extensive testing to prove correctness and backwards compatibility. I haven't found the time to complete that.
