Raspberry Pi Pico: how to access the filesystem
Eureka!
Yikes, that's novel. Is it documented anywhere? It does indeed work.
Thank you for your help.
Spoke too soon...
Now reverted to standard _boot.py. I can read from /pyboard but not write to it:
Trying to edit a file from within rshell produced a hang.
The editor read the file but it hung when I tried to save the changed contents.
[EDIT]
It works properly when mounted at /flash.
/home/adminpete/bin> cp pyplayerc.py /pyboard/
timed out or error in transfer to remote: b''
/mnt/qnap2/data/Projects/MicroPython/rshell> ls /pyboard/
rats.py
/mnt/qnap2/data/Projects/MicroPython/rshell> edit /pyboard/rats.py
Retrieving /pyboard/rats.py ...
Updating /pyboard/rats.py ...
[EDIT]
Re: Raspberry Pi Pico: how to access the filesystem
Yeah, rshell creates a virtual directory for each board using the board name (which defaults to pyboard).
It always puts the root directory of the pyboard under this virtual directory.
As a convenience, for the first board connected, rshell will also create virtual directories for the directories under '/' on the pyboard (which works out ok for say the pyboard which only has l/flash and /sd) and gets a bit more confusing when the filesystem is mounted at /.
The rshell boards command will show all of the virtual directories created for a given board.
Any thoughts as to why I couldn't write to /pyboard?
You should be able to write to /pyboard and it should write to / on the pyboard.
I have a couple RPi Picos coming in the mail, so I'll play around with them and see if there is something weird going on.
If you run rshell with the -d option and try copying a file, it will print out the body of the function recv_file_from_host and then print the invocation (about 10 lines up from the prompt) and you should see something like this: I did this on a pyboard, on the Pico I would expect to see a filename like '/heartbeat.py'.
The python code then tries to open that filename using:
output = recv_file_from_host(None, '/flash/heartbeat.py', 149)
with open(dst_filename, dst_mode) as dst_file:[code] receives data over the serial port and writes it to the file.
dst_mode will be 'wb'. Can you try manually writing to the file using a similar with statement?
Ignore all the stuff about mountpoints. Even with _boot.py set to mount at /flash the thing does not work properly. I've now tested this on two Linux PC's with the same outcome: reading is OK but writes time out. Regardless of mountpoint.
tl;dr I think there is a communications problem. You are better placed than me to figure out whether the fault is in the board firmware or in rshell.
Using the -d option, with mountpoint '/', here is the outcome:
At this point communications seemed to be cattled because the following hung:
After a power cycle I found that the filename had been copied but attempting to cat the file or list it showed that the contents had not been copied.
Executing "cp pyplayerc.py /pyboard"
----- About to send 458 bytes of code to the pyboard -----
def get_mode(filename):
"""Returns the mode of a file, which can be used to determine if a file
exists, if a file is a file or a directory.
import os
# Since this function runs remotely, it can't depend on other functions,
# so we can't call stat_mode.
return os.stat(filename)[0]
except OSError:
return 0
output = get_mode('/')
if output is None:
print("None")
print(output)
-----Response-----
b'16384\r\n'
----- About to send 2263 bytes of code to the pyboard -----
def recv_file_from_host(src_file, dst_filename, filesize, dst_mode='wb'):
"""Function which runs on the pyboard. Matches up with send_file_to_remote."""
import sys
import ubinascii
import os
if False:
usb = pyb.USB_VCP()
except:
usb = machine.USB_VCP()
except:
usb = None
if usb and usb.isconnected():
# We don't want 0x03 bytes in the data to be interpreted as a Control-C
# This gets reset each time the REPL runs a line, so we don't need to
# worry about resetting it ourselves
usb.setinterrupt(-1)
bytes_remaining = filesize
if not False:
bytes_remaining *= 2 # hexlify makes each byte into 2
buf_size = 32
write_buf = bytearray(buf_size)
read_buf = bytearray(buf_size)
while bytes_remaining > 0:
# Send back an ack as a form of flow control
sys.stdout.write('\x06')
read_size = min(bytes_remaining, buf_size)
buf_remaining = read_size
buf_index = 0
while buf_remaining > 0:
if False:
bytes_read = sys.stdin.buffer.readinto(read_buf, read_size)
bytes_read = sys.stdin.readinto(read_buf, read_size)
if bytes_read > 0:
write_buf[buf_index:bytes_read] = read_buf[0:bytes_read]
buf_index += bytes_read
buf_remaining -= bytes_read
if False:
dst_file.write(write_buf[0:read_size])
dst_file.write(ubinascii.unhexlify(write_buf[0:read_size]))
if hasattr(os, 'sync'):
os.sync()
bytes_remaining -= read_size
return True
except:
return False
output = recv_file_from_host(None, '/pyplayerc.py', 2621)
if output is None:
print("None")
print(output)
/home/adminpete/bin> ls /pyboard
Executing "ls /pyboard"
----- About to send 626 bytes of code to the pyboard -----
def stat(filename):
"""Returns os.stat for a given file, adjusting the timestamps as appropriate."""
import os
# on the host, lstat won't try to follow symlinks
rstat = os.lstat(filename)
except:
rstat = os.stat(filename)
return rstat[:7] + tuple(tim + 0 for tim in rstat[7:])
def get_stat(filename):
"""Returns the stat array for a given file. Returns all 0's if the file
doesn't exist.
return stat(filename)
except OSError:
return (0,) * 10
output = get_stat('/')
if output is None:
print("None")
print(output)
/home/adminpete> ls -l /flash
0 Jan 1 1970 pyplayerc.py
23 Jan 1 00:01 rats.py
ESP8266 and ESP32 with rshell are always mounted as /pyboard (With default last stable generic build from here micropython.org)aivarannamaa wrote: ↑Tue Jan 26, 2021 4:51 pmDefault builds for ESP8266, ESP32 and CircuitPython also mount at '/'. I was thinking of PyBoard and some ESP builds (eg M5Stack) with their /flash to be exceptions
I never seen mounted anywhere else with many different boards ESP*
- aivarannamaa
It looks like I misunderstood the discussion. I meant how the flash is mounted inside the MicroPython VM (eg you have /main.py on some devices vs /flash/main.py on others), but now I see the others were talking about how rshell presents it. Thank you for pointing this out!JumpZero wrote: ↑Wed Jan 27, 2021 8:49 amESP8266 and ESP32 with rshell are always mounted as /pyboard (With default last stable generic build from here micropython.org)aivarannamaa wrote: ↑Tue Jan 26, 2021 4:51 pmDefault builds for ESP8266, ESP32 and CircuitPython also mount at '/'. I was thinking of PyBoard and some ESP builds (eg M5Stack) with their /flash to be exceptions
Aivar Annamaa
https://thonny.org
https://thonny.org
If on the target a file board.py exists, which define a symbol called name with the name of that board, pyboard mounts the board under that name. e.g a board,py file with the content:
name = "esp32"
causes the board mounter under the directory /esp32. Side effect: If you use:
name = ""
the board will be mounted under /, but no files can be copied to that place. Using e.g. esp32 works.
name = "esp32"
name = ""
Just an update on the unability to write back to the pico board with rshell.
- I created a file board.py on the pico and called the board "rp2"
I can use cp or rm to create or delete file on the board (path /rp2/....)
I cannot edit files on the board using vi or nano. The file will be loaded, but cannot be written back.
I CAN edit files & write them back with the linux version of my pye editor. One difference to nano or vi: pye does not attempt to restore file permissions. It just renames the old file to a tempname, creates a new file under the old name, and then deletes the temp named file.
