Pico Mounting SD Card
Re: Pico Mounting SD Card
There was not much to implement, and I tried it out of own interest. And last not least - I have to learn dealing with cmake. And taht was at least a start.
The build works like a charm, I can now log data on the built in flash and whenever someone wants to get the data they can press a button and it copies the data to the SD card. I'm doing this as I'm trying to reduce power consumption, and I've read that writing to an SD card has a relatively high power consumption. If anyone happens to know if limiting the SD card usage actually makes a difference to power consumption that would be great, otherwise I'll probably power my data logger on 3 AAs and find out whether logging to the built in memory or the SD card makes any difference to the run time of the device.
Thanks for your help.
I'm still struggling with the Pico and an SD card.
Here is what i did in Micropython 1.16
From the previous posts I understood that the problem is a missing FAT support of uos?
Though, if that was true, why do I only get an error when I try to mount the file system?
Roberthh posted a link for Micropython WITH Fat support,
https://github.com/robert-hh/micropython/tree/rp2_fat
but it goes into the void for me.
Could someone share his wisdom with me? I would be very glad to log measuring values on an external medium, as the internal storage is rather limited.
>>> from machine import SPI, Pin
>>> import uos
>>> import sdcard
>>> sd = sdcard.SDCard(SPI(1), Pin(9))
>>> vfs = uos.VfsFat(sd)
>>> uos.mount(vfs, "/sd")
OSError: [Errno 19] ENODEV
FAT support is included in v1.16. otherwise VfsFat would not exist. I mounted already SD card on RP2, so it's possible. Error 19 indicates that the file system could not be detected. The SD card must only have a single FAT partition. Sometimes new cards have another small partition as the first one. That confused the driver. And not all cards work. I tested it with Samsung, Sandisk and Transcend cards in to he range of 8 to 64 GB.
Thank you, Robert!
Good news:
Just now I succeeded in mounting another freshly formatted (FAT32) card in a folder "/test" I had created in the internal file system of the Pico.
Here is the code:
The unmount at the end is important, otherwise I get an error when restarting the program, as the card is already mounted.
Good news:
Here is the code:
import uos
import sdcard
uos.mount(vfs, "/test")
l = uos.listdir("/test")
print(l)
uos.umount("/test")
I have tested several SDcards, 4 out of 9 worked, the other produced errors:
or
in init_card
though the cards worked fine in Linux Mint on my computer, and though they were freshly formatted.
Maybe this is due to a timing problem?
I recall a similar behavior of some cards in Arduino.
OSError: timeout waiting for v1 card
OSError: no SD card
Here is a small test program that works for me:
The test program mounts the card under “/SD” in the Pico file system.
If there is no “/SD” folder, it is created.
After this, it lists the directory on the card, writes a test file and reads it back.
At last the card is unmounted.
import uos
import sdcard
sdfolder = "/SD"
def readfile(fname):
f = open(fname, 'r')
t = f.read()
f.close()
print(t)
def writefile(fname, text):
f = open(fname, 'w')
f.write(text)
f.close()
def mountsdcard(sdfolder):
create_mountpoint(sdfolder)
uos.mount(vfs, sdfolder)
def create_mountpoint(sdfolder):
print("Creating SD mountpoint " + sdfolder)
uos.mkdir(sdfolder)
except:
# remove trailing '/' before checking -> sdfolder[1:]
if sdfolder[1:] in uos.listdir("/"):
print ("Mountpoint already there: " + sdfolder)
print("Could not create SD mountpoint + sdfolder")
l = uos.listdir(sdfolder)
print(l)
writefile(sdfolder + "/blah.txt", "Blahblah\npi = 3.14")
readfile(sdfolder + "/blah.txt")
uos.umount(sdfolder)
I am currently working on a set of tools that makes using an SD card easier.
There is an object defining the SD card with functions to mount, unmount, list files / folders etc.
The usage is like this:
And the class and functions definition is here (not ready, but in part already usable)
Feedback is welcome.
if __name__ == "__main__":
sdfolder = "/SD" # (mountpoint)
SPIselect = 0 # 0/1 for SPI0 or SPI1
SD_CS = 5 # Chip select for SD (may be any GP pin)
sd = SD(SPIselect, SD_CS, sdfolder)
if sd.error:
print(sd.error)
print("SD folder: ", sd.sdfolder)
l = sd.list_all()
print("Files and folders on SD: ", l)
l = sd.listfolders()
print("Folders on SD: ", l)
l = sd.listfiles()
print("Files on SD: ", l)
sd.unmount()
import uos
import sdcard
from machine import SPI, Pin, UART, I2C
# TOOLS
def is_folder(filename):
# True if folder
if uos.stat(filename)[0] & 0x4000:
return True
return False
def is_file(filename):
# True if file, not folder
if uos.stat(filename)[0] & 0x8000:
return True
return False
def list_folders(folder):
# list subfolders of folder
l = uos.listdir(folder)
folders = []
for f in l:
f = folder + '/' + f
if is_folder(f):
folders.append(f)
##folders = [f for f in l if is_folder(f)] ## this gives error if no folder there
return folders
def list_files(folder):
# list files in folder (subfolders excluded)
files = []
for f in l:
if is_file(f):
files.append(f)
#files = [f for f in l if is_file(f)]
return files
# MAIN SD class, needs sdcard.py (driver)
class SD():
def __init__(self, SPIselect, SD_CS, sdfolder):
print("Defining SD")
self.SPIselect = SPIselect
self.SD_CS = SD_CS
self.sdfolder = sdfolder
self.error = ""
# define SD
self.sd = sdcard.SDCard(SPI(SPIselect), Pin(SD_CS))
except OSError as e:
self.error = (str(e))
self.sd = None
except:
self.error = "SD card ERROR"
self.sd = None
# mount SD
self.mountsdcard()
def mountsdcard(self):
print("Mounting SD")
self._create_mountpoint()
vfs = uos.VfsFat(self.sd)
uos.mount(vfs, self.sdfolder)
self.error = ""
if "EPERM" in str(e):
print("SD card already mounted!")
self.error = ""
self.error += '\t' + "MOUNT ERROR"
except Exception:
def _create_mountpoint(self):
# if sdfolder does not exist, create it (to use as mountpoint)
if (self.sdfolder in list_folders('/') == False):
uos.mkdir(self.sdfolder)
def unmount(self):
print("Unmounting SD card")
uos.umount(self.sdfolder)
def list_all(self):
return uos.listdir(self.sdfolder)
def listfolders(self):
return list_folders(self.sdfolder)
def listfiles(self):
return list_files(self.sdfolder)
t = f.read()
f.close()
return t
print(t)
f = open( fname, 'a')
f.write(text + '\n')
f.close()
That looks fine and useful. For comparison and ideas, you may also have a look at https://github.com/pfalcon/micropython-lib.git, folder upysh.
Thanks Robert,
I had a look. Must confess that I did not understand everything, but it looks interesting.
Here is my more or less ready version of "filetools.py":
For me sd.print is especially interesting, as I can use it like print to Serial.
Also sd.error is a variable that I can use at any time to see if everything's right, especially if the sd card is mounted correctly.
Maybe sd.error should be updated also in sd.readfile or sd._write2file?
''' filetools by jean-claude.feltes@education.lu
for working with SD card'''
import uos
import sdcard
# FILE TOOLS
# True if folder
return True
return False
return True
return False
folders = []
for f in l:
fi = folder + '/' + f
if is_folder(fi):
folders.append(f)
return folders
files = []
for f in l:
if is_file(fi):
files.append(f)
return files
# SD TOOLS
class SD():
self.SD_CS = SD_CS
self.error = ""
# define SD
self.sd = None
except:
self.sd = None
# mount SD
self.mountsdcard()
self.error = ""
self.error = ""
except Exception:
def unmount(self):
def list_all(self):
def readfile(self, fname):
fname = self.sdfolder + '/' + fname
t = f.read()
f.close()
return t
def _write2file(self, fname, text, mode = 'a', end = '\n'):
# mode = 'a' (append) or 'w' (write)
f = open( fname, mode)
f.write(text + end)
f.close()
def writefile(self, fname, text):
# writes a new file to SD card
self._write2file(fname, text, mode = 'w')
def print(self, fname, text, end = '\n'):
# works like print, but to a file on the SD card
# appends text to file fname with line feed at the end
self._write2file(fname, text, mode = 'a', end = end)
sdfolder = "/SD"
if sd.error:
print(sd.error)
l = sd.list_all()
l = sd.listfiles()
t = 'Blahblah ghjghg pi'
sd.writefile('blah.txt', t)
t = "This is appended to the file"
sd.print('blah.txt', t)
t = sd.readfile('blah.txt')
print(t)
sd.unmount()
