MFRC522 on pico
JMSMonkey
MFRC522 on pico
Post by JMSMonkey » Mon Feb 08, 2021 9:40 pm
hi,
I have been using the MFRC522 RFID reader on a pi zero for a while now to operate a door lock using the tutorial from PiMyLifeUp (tutorial - https://pimylifeup.com/raspberry-pi-rfid-rc522/ script - https://github.com/pimylifeup/MFRC522-python). From this I'm able to use the text written to the card to lock or unlock the door.
I am a newbie when it comes to coding and was hoping that I could use the same program on the new pico but I was wrong due to differences between python and micropython.
I have tried finding a micropython version of the script to do the same thing but I can't find one that allows writing text to the card (using the 1K EEPROM on the cards and tags).
how would I go about changing the PiMyLifeUp script to run on micropython or does anyone know of an existing one that will do the same job?
thanks in advance for any help you can give.
danjperron
Re: MFRC522 on pico
Post by danjperron » Thu Feb 11, 2021 7:29 pm
I put micropython code on the raspberry forum
https://www.raspberrypi.org/forums/view ... 9#p1816948
Nicolett
Re: MFRC522 on pico
Post by Nicolett » Fri May 20, 2022 11:43 am
I've designed a smart lock project for my entrance door. I made the case on my 3d printer and I've used a raspberry module, integrated a camera, a fingerprint module, a digital card locker and a bluetooth module. The code took me nearly a week. I've also contacted a tower hill locksmith service (a friend of mine is working there) to design this lock in a proper way, to make it work as it should. Now it's the second week of testing, if it will go as good as it has been, I'll start a kickstarter campaign to gather 10K$ to start a small production
