I'm struggling to get SPI working, either hard or soft.
Issuing a soft SPI write produces a clock burst of the specified frequency but the data pin is stuck low. I've tried different data pins to no effect. I am using the machine.SoftSPI constructor.
If anyone has got hard or soft SPI output to work, please could you post your SPI initialisation code.
[SOLVED] SPI on the Pico: has anyone made it work?
Re: SPI on the Pico: has anyone made it work?
I have adapted a driver for an oled display using sh1122. It is using SPI. Code is here viewtopic.php?f=14&t=9769 it runs without any problem on my Pico.
Hello Peter, I have used your flash_spi driver to attach a SPI flash chip as drive. Start-up code:
from machine import SPI, Pin
import os
spi = SPI(0, baudrate=10_000_000, polarity=1, phase=1,
sck=Pin(18), mosi=Pin(19), miso=Pin(16))
from flash_spi import FLASH
cspins = (Pin(17, Pin.OUT, value=1),)
flash = FLASH(spi, cspins, cmdset=False)
os.mount(flash, "/spi")
print(os.listdir("/spi"))
Thanks both, I'll try again; maybe I was suffering from "finger trouble".
@Roberthh interesting that you are using hard SPI on nonstandard pins. I didn't know you could do that on the rp2, although the Pi Pico doc hints at it by referring to "default SPI pins".
I just did that w/o reading the docs. I just had looked at the Pinout. But i had glanced before into the code and noticed that is checked for a variety of pins for being valid.
Well I don't know what I was doing yesterday but today it's working fine. Thanks for the pointers.
