Hi there,
I just posted a question on the rpi microPython forum but have since found the answer.
Apparently ucollections doesn't support deque on the rpi pico.
Can anybody tell me how to create a fifo buffer that I can fill with interrupt timestamps?
I am trying to hook my pi up to an ergometer to calculate speed, work, distance etc.
The machine has a rpm sensor and I am trying to read the time difference between pulses.
My thinking was that to keep the interrupt handler as fast as possible so I would store the timestamp in a buffer and read that buffer in a slow loop to update the display.
This whole programming without documentation thing is quite challenging.
FIFO buffer for interrupt timestamps
Re: FIFO buffer for interrupt timestamps
You can implement it with a circular buffer, which is either global, or a class member in a class which also contains the irq response function.
Circular buffers are easy to implement and a common design. You'll find a lot about that in the Internet.
Thank you very much.
This is my first project that has wires coming out of it and I keep running into problems because I know what I want but I just don't know the words for it.
Circular buffer sounds exactly right
I think I have successfully implemented a ring-buffer.
Thank you for the help.
import utime
import array
class MySensor:
sensorGPIOPin = 4
bounce = 5000
pulse = 0
myRB = array.array('i',[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0])
rb_len = 0
w_cursor = 0
r_cursor = 0
sensor = None
oldTime = 0
def init_GPIO(self): # initialize GPIO
self.sensor = machine.Pin(self.sensorGPIOPin, machine.Pin.IN, machine.Pin.PULL_DOWN)
def init_interrupt(self):
self.oldTime = utime.ticks_us()
self.sensor.irq(trigger=machine.Pin.IRQ_FALLING, handler=self.mark_time)
def mark_time(self,channel): # callback function
self.pulse+=1 # increase pulse by 1 whenever interrupt occurred
newTime = utime.ticks_us()
dT = utime.ticks_diff(newTime,self.oldTime)
if dT > self.bounce:
self.write(dT)
self.oldTime = newTime
def write(self,time):
self.myRB[self.w_cursor] = time
self.w_cursor+=1
if self.w_cursor >= self.rb_len:
self.w_cursor = 0
def read(self):
if self.r_cursor != self.w_cursor:
val = self.myRB[self.r_cursor]
self.r_cursor += 1
if self.r_cursor >= self.rb_len:
self.r_cursor = 0
val = False
return val
def __init__(self, pinNr):
self.rb_len = len(self.myRB)
self.sensorGPIOPin = pinNr
self.init_GPIO()
self.init_interrupt()
