Multicore support
Tinus
Multicore support
Post by Tinus » Sun Feb 14, 2021 5:49 pm
There is something I don't quite understand in the pi pico MicroPython SDK pdf
it says:
Only one thread can be started/running at any one time, because there is no RTOS just a second core. The GIL is not
enabled so both core0 and core1 can run Python code concurrently, with care to use locks for shared data
I think that is a good thing because I assume I can do calculations on one core and run the display from the other.
However I do not know how to lock shared data or if I even should.
I also assumed that the main program runs on one core and if I start the extra thread it will run on the other core. Is that assumption correct?
Re: Multicore support
Post by jimmo » Mon Feb 15, 2021 1:57 am
Yes that's exactly right. There's no "OS" as such, so no pre-emptive multitasking or thread switching etc. MicroPython just provides one thread per core (or more accurately, a "main" thread on the first core and an optional second thread).
Yes, you should. Unlike other Python implementations (including other MicroPython ports), MicroPython on the Pico doesn't use the "Global Interpreter Lock" so both threads run completely concurrently.
The _thread module provides a lock primitive (see _thread.allocate_lock() ) -- https://docs.python.org/3.5/library/_th ... le-_thread
Tinus
Post by Tinus » Mon Feb 15, 2021 1:29 pm
Thank you very much.
