PIO Pulse Counter
PIO Pulse Counter
Post by dhylands » Tue Feb 16, 2021 2:03 am
I've been learning about the PIO, so I've started creating some little test programs to explore various aspects of the PIO.
My first example is a Pulse Counter. It just counts the number of rising edges on a Pin.
https://github.com/dhylands/upy-example ... counter.py
# Example using PIO to count pulses on an input pin.
# The following assumes Pin 17 is jumper to Pin 16
#   pin16 = Pin(16, Pin.IN, Pin.PULL_UP)
#   pin17 = Pin(17, Pin.OUT)
#   pin17.low()
#   pc = PulseCounter(0, pin16)
#   print("pulse count =", pc.get_pulse_count())
#   pin17.high()
#   pin17.low()
#   pin17.high()
#   pin17.low()
import rp2
@rp2.asm_pio()
def pulse_counter():
    label("loop")
    # We wait for a rising edge
    wait(0, pin, 0)
    wait(1, pin, 0)
    jmp(x_dec, "loop")  # If x is zero, then we'll wrap back to beginning
class PulseCounter:
    # pin should be a machine.Pin instance
    def __init__(self, sm_id, pin):
        self.sm = rp2.StateMachine(0, pulse_counter, in_base=pin)
        # Initialize x to zero
        self.sm.put(0)
        self.sm.exec("pull()")
        self.sm.exec("mov(x, osr)")
        # Start the StateMachine's running.
        self.sm.active(1)
    def get_pulse_count(self):
        self.sm.exec("mov(isr, x)")
        self.sm.exec("push()")
        # Since the PIO can only decrement, convert it back into +ve
        return -self.sm.get() & 0x7fffffff
JumpZero
Re: PIO Pulse Counter
Post by JumpZero » Tue Feb 16, 2021 5:51 pm
Thanks,
tested it works!
just needed to add "from machine import Pin" but was obvious
I'll be curious to see the max frequency this PIO counter can measure. Maybe when I have time, I can try
Georgeskingv
Post by Georgeskingv » Mon Feb 22, 2021 4:53 pm
Nice,
I will try to modify it to make a quadrature encoder.
Best regards
Georges
Post by dhylands » Mon Feb 22, 2021 9:28 pm
Somebody else posted a quadrature encoder, but it puts the pulses in the FIFO and requires the MCU to do the accumulation.
My end goal is also to implement a quadrature encoder where the counter is maintained inside the PIO.
One of the keys is figuring out how to decrement and increment a counter. You can decrement using the JMP statement. Something like:
    jmp(x_dec, next)
    label(next)
will decrement (the decrement that's part of the jmp always happens whether the jump occurs or not) . And I think if you do an invert, decrement, invert, then that should do an add of 1. Then it just boils down to doing the state machine for the gray codes.
Georgeskingv
Post by Georgeskingv » Tue Feb 23, 2021 8:03 am
An idea is to decrement X or Y depending of the direction and then take the difference !
Best regards
Georges
