PIO Pulse Counter
Posted: Tue Feb 16, 2021 2:03 am
I've been learning about the PIO, so I've started creating some little test programs to explore various aspects of the PIO.
My first example is a Pulse Counter. It just counts the number of rising edges on a Pin.
https://github.com/dhylands/upy-example ... counter.py
# Example using PIO to count pulses on an input pin.
# The following assumes Pin 17 is jumper to Pin 16
# pin16 = Pin(16, Pin.IN, Pin.PULL_UP)
# pin17 = Pin(17, Pin.OUT)
# pin17.low()
# pc = PulseCounter(0, pin16)
# print("pulse count =", pc.get_pulse_count())
# pin17.high()
# pin17.low()
# pin17.high()
# pin17.low()
import rp2
@rp2.asm_pio()
def pulse_counter():
label("loop")
# We wait for a rising edge
wait(0, pin, 0)
wait(1, pin, 0)
jmp(x_dec, "loop") # If x is zero, then we'll wrap back to beginning
class PulseCounter:
# pin should be a machine.Pin instance
def __init__(self, sm_id, pin):
self.sm = rp2.StateMachine(0, pulse_counter, in_base=pin)
# Initialize x to zero
self.sm.put(0)
self.sm.exec("pull()")
self.sm.exec("mov(x, osr)")
# Start the StateMachine's running.
self.sm.active(1)
def get_pulse_count(self):
self.sm.exec("mov(isr, x)")
self.sm.exec("push()")
# Since the PIO can only decrement, convert it back into +ve
return -self.sm.get() & 0x7fffffff
