Capacitive Touch Sensor using PIO - how to set jmp_pin? [solved]
cebersp
Post by cebersp » Tue Feb 16, 2021 5:21 pm
Edit: See post 3 for working code!
Hi, I would like to do a cap-sensor again but with PIO for better resolution.
viewtopic.php?f=5&t=9829
Two GPIOs are used. One (16) is output and coupled via a 1 Megaohms resistor to the metal pad. The second (17) is coupled directly to the metal pad. The time needed to charge the capacity of the pad is measured. With increased capacity a longer time is needed.
I need to jump on pin state. Something like
jmp(pin, "target_label")
Where can I find the docu about PIO assembler?
Thank you very much!
Christof
title= "pioTouchA"
# from Example of using PIO for PWM, and fading the brightness of an LED
from rp2 import PIO, StateMachine, asm_pio
from time import sleep
@asm_pio(sideset_init=PIO.OUT_LOW)
def cap_prog():
    mov(y, osr) .side(1) # ISR must be preloaded with max
    #mov(x, osr) .side(1) # ISR must be preloaded with max
    label("test_pin") # count down y, until inPin is high
    nop()
    jmp(pin, "is_set") # does not work!
    #nop() [5]
    jmp(y_dec, "test_pin") # tested
    label("is_set")
    mov(isr, y) .side(0) # pin low
    push(block)
class PIOCAP:
    def __init__(self, sm_id, outPin, inPin, max_count, count_freq):
        self._sm = StateMachine(sm_id, cap_prog, freq=2 * count_freq, sideset_base=Pin(outPin), jmp_pin=Pin(inPin))
        # Use exec() to load max count into ISR
        self._sm.put(max_count)
        self._sm.exec("pull()")
        #self._sm.exec("mov(isr, osr)")
        self._sm.active(1)
        self._max_count = max_count
# Pin 16 is output
#cap = PIOCAP(0, 16, 17, max_count=(1 << 16) - 1, count_freq=10_000_000)
cap = PIOCAP(0, 16, 17, max_count=(1000), count_freq=10_000_000)
    print(cap._sm.get())
    sleep(0.01)
Re: PIO how to set jmp_pin?
Post by dhylands » Tue Feb 16, 2021 7:03 pm
The documentation for the PIO assembler can be found in the RP2040 datasheet. https://datasheets.raspberrypi.org/rp20 ... asheet.pdf starting at page 324.
I haven't seen any documentation on the Micropython assembler syntax. I've use the examples found in the micropython/examples/rp2 directory, and https://hackspace.raspberrypi.org/books ... ython-pico has some examples/verbage in Appendix C (page 130)
I've also found looking at: https://github.com/micropython/micropyt ... les/rp2.py to be useful. If you're looking for jmp modifiers (like !x is really not_x) or mov modifiers (like invert) you'll find them in this file.
It also has the assembler functions (i.e. jmp/mov/wait/...) and you can see what arguments all of the functions expect.
There is an example of jmp(pin, "target") in the pio_uart_rx.py file: https://github.com/micropython/micropyt ... _rx.py#L58
cebersp
Post by cebersp » Tue Feb 16, 2021 7:16 pm
Thank You very much Dave!
Yes I did have a close look into the datasheet.
I learned, how to do it here:
https://www.raspberrypi.org/forums/view ... 6&t=303606
I do not at all understand it, but the following code works now!
I did learn how to get the result from your code.
Christof
title= "pioTouchB"
maxTime=10000
def cap_prog():
    mov(y, osr) .side(1) # OSR must be preloaded with max
    jmp(pin, "is_set") # does work
    label("is_set")
    mov(isr, y) .side(0) # save result pin low
    label("delayLow")
    nop()
    jmp(x_dec, "delayLow") # tested
class PIOCAP:
        self._sm = StateMachine(sm_id, cap_prog, freq=2 * count_freq, sideset_base=Pin(outPin), jmp_pin=Pin(inPin,Pin.IN))
        self._sm.active(1)
    def getCap(self):
        self._sm.exec("push()")
        # Since the PIO can only decrement, convert it back into +ve
        return self._sm.get()
# Pin 16 is output
cap = PIOCAP(0, 16, 17, max_count=(maxTime), count_freq=10_000_000)
    print(maxTime-cap.getCap())
    sleep(0.01)
