Capacitive Touch Sensor using PIO - how to set jmp_pin? [solved]
Posted: Tue Feb 16, 2021 5:21 pm
Edit: See post 3 for working code!
Hi, I would like to do a cap-sensor again but with PIO for better resolution.
viewtopic.php?f=5&t=9829
Two GPIOs are used. One (16) is output and coupled via a 1 Megaohms resistor to the metal pad. The second (17) is coupled directly to the metal pad. The time needed to charge the capacity of the pad is measured. With increased capacity a longer time is needed.
I need to jump on pin state. Something like
jmp(pin, "target_label")
Where can I find the docu about PIO assembler?
Thank you very much!
Christof
Christof
title= "pioTouchA"
# from Example of using PIO for PWM, and fading the brightness of an LED
from rp2 import PIO, StateMachine, asm_pio
from time import sleep
@asm_pio(sideset_init=PIO.OUT_LOW)
def cap_prog():
mov(y, osr) .side(1) # ISR must be preloaded with max
#mov(x, osr) .side(1) # ISR must be preloaded with max
label("test_pin") # count down y, until inPin is high
nop()
jmp(pin, "is_set") # does not work!
#nop() [5]
jmp(y_dec, "test_pin") # tested
label("is_set")
mov(isr, y) .side(0) # pin low
push(block)
class PIOCAP:
def __init__(self, sm_id, outPin, inPin, max_count, count_freq):
self._sm = StateMachine(sm_id, cap_prog, freq=2 * count_freq, sideset_base=Pin(outPin), jmp_pin=Pin(inPin))
# Use exec() to load max count into ISR
self._sm.put(max_count)
self._sm.exec("pull()")
#self._sm.exec("mov(isr, osr)")
self._sm.active(1)
self._max_count = max_count
# Pin 16 is output
#cap = PIOCAP(0, 16, 17, max_count=(1 << 16) - 1, count_freq=10_000_000)
cap = PIOCAP(0, 16, 17, max_count=(1000), count_freq=10_000_000)
print(cap._sm.get())
sleep(0.01)
