mandelbrot calculation and strange behavior in PICO
shaoziyang
Post by shaoziyang » Wed Feb 17, 2021 7:49 am
I have modify [*]examples/mandel.py[*] for performance testing.
from time import ticks_ms, ticks_diff
MAX_ITER = 60
MANDEL_CHAR = (
    ' ', '.', '`', ',', ':', ';', '|', 'o', '<', '>',
def run(func, param = None):
    t1 = ticks_ms()
    if param == None:
        func()
        func(param)
    t2 = ticks_ms()
    print('calc time:', ticks_diff(t2, t1), 'ms')
# @micropython.native
def calc_mandel(c):
    z = 0
    for i in range(MAX_ITER):
        z = z * z + c
        if abs(z) > 4:
            return i
    return MAX_ITER - 1
def mandelbrot():
    N = len(MANDEL_CHAR)
    print('')
    for v in range(31):
        for u in range(81):
            n = calc_mandel((u / 30 - 2) + (v / 15 - 1) * 1j)
            print(MANDEL_CHAR[(MAX_ITER - n - 1)%N], end='')
        print()
run(mandelbrot)
Running results
----------------------==================~~~~~~~~+++}}{)(o-<){}++~~~~~~=========--
-------------------==================~~~~~~~~++++}}{>oo:  ,>>(}+++~~~~~~========-
-------------================~~~~~~~~~~+++}}}{{{{))(o~      :(){{}}}+++++~~~=====
----------===============~~~~~~~~~~~++++})-@><((o>o :`=    .:|;< >){{{)`}+~~~====
-------==============~~~~~~~~~~~~+++++}}{)o.  ~,+                ,<<@:; :}+~~~===
--=============~~~~~+++++++++++}}}}}}{)#:@`                          #o({}++~~~==
-===========~~~~~~++}{<({{}{{){{{{{{{)(<:;                             o>>)++~~==
==========~~~~~~~+++}{>o<<>(>`o((())((<=                                 #)++~~~=
~~~+++})}}}}{{{))>o=);-                                                >{}++~~~~=
        -o()}}++~~~~=
shaoziyang
Re: mandelbrot calculation and strange behavior in PICO
Post by shaoziyang » Wed Feb 17, 2021 7:53 am
It works in PICO, but I have found a strange behavior in PICO, the calculation time increases each time, tens to hundreds of milliseconds each time. There is no such phenomenon on other hardware (such as pyboard, esp32, microbit).
Is this a bug in PICO firmware?
shaoziyang
Post by shaoziyang » Fri Feb 19, 2021 12:57 pm
calc time: 3526 ms
calc time: 3573 ms
calc time: 3627 ms
calc time: 3666 ms
calc time: 3719 ms
calc time: 3758 ms
calc time: 3812 ms
calc time: 3852 ms
yeti
Post by yeti » Fri Feb 19, 2021 3:55 pm
Can you add a garbage collection run before running the test?
I have a natural instinct for science. — D.J. Trump
"Don't we all wait for SOMETHING-ELSE-1.0?" — yeti
"Stay OmmmMMMmmmPtimistic!" — yeti
shaoziyang
Post by shaoziyang » Sat Feb 20, 2021 1:08 am
I have try to add gc.collect() before calculation, it will decrease the increase time slightly.
It appears to be caused by the print function, this problem only appear on PICO.
Post by pythoncoder » Sat Feb 20, 2021 10:23 am
...It appears to be caused by the print function, this problem only appear on PICO.
Interesting. There seem to be a number of issues around the Pico USB interface.
Richardm
Post by Richardm » Mon Feb 22, 2021 8:44 pm
Prime candidate for multi core. I tried and got 5 rows to run in parallel. Will retry when core1 support is a bit further along.
