ADC read frequency
mironk
ADC read frequency
Post by mironk » Fri Feb 19, 2021 12:16 pm
Hi! What maximum adc rate is possible with RPI pico? I used the code below and 1e6 ADC reads takes about 60s. It is about 16kHz. Is there any method to obtain 0.5 - 1 MHz?
import utime
time_start = utime.time_ns()
for i in range(1000000):
    adc=machine.ADC(26)
    val=adc.read_u16()
    time_stop = utime.time_ns()
elapsed_time = time_stop-time_start
time_s = elapsed_time /1000000000.00
print(time_s)
HerbV
Re: ADC read frequency
Post by HerbV » Sat Feb 20, 2021 9:48 am
your code could be around 3 times faster, but still not 0.5 to 1Mhz
i
mport utime
adc=machine.ADC(26)
for i in range(100000):
    val=adc.read_u16()
print(time_s)
Did you try that: https://www.hackster.io/AlexWulff/adc-s ... ico-f883dd
Post by Roberthh » Sat Feb 20, 2021 1:01 pm
According to the data sheet the maximum sample rate is 500ks/sec. The only way to transfer data at this rate is by using DMA. The rate at which the ADC runs can be configured. Python itself has no direct access to configure DMA and the ADC registers, but you can use viper code to do that. For DMA, examples are in this thread: viewtopic.php?f=21&t=9697&start=20
You will need to refer to the RP2040 data sheet for proper settings.
mironk
Post by mironk » Sun Feb 21, 2021 1:08 pm
i
mport utime
adc=machine.ADC(26)
    val=adc.read_u16()
print(time_s)
Thanks. Your suggestion indeed improved the ADC rate.
mironk
Post by mironk » Sun Feb 21, 2021 1:09 pm
mironk
Post by mironk » Sun Feb 21, 2021 1:11 pm
Thanks. I will try. But I am afraid it will be hard task to me. I am novice :)
