Does Pyboard D support UART flow control?, It doesn't say anything in the documentation!
Cheers,
Howard.
Re: Does Pyboard D support UART flow control?
Those PR's seem to be about ESP32 (your own PR changes only docs and ports/esp32/machine_uart.c).
The query is about the Pyboard D.
While I haven't tested this, I'd be very surprised if the Pyboard D didn't support it exactly as per the Pyboard 1.x. Support is via the pyb module which is shared by both. RTS/CTS flow control definitely works on Pyboard 1.x.
You're right. Sometimes reading every word helps.
