I am working on a project where i want to use micropython on an stm32f417 controller , i´ve figured out that there is no micropython available for this controller , so i should maybe work on the firmware of STM32F407 to let it compatible for my controller and than upload it to the controller for that reason i am starting to see what i should change in the firmware of "STM32F407" ,
i get the conclusion that i should change the
1 : "mpconfigboard.h"
2: "stm32f4xx_hal_conf.h"
3:"mpconfigboard.mk"
i could change the two header file (1 , 2) but for the make file i am confused about what i should change exactly also for the linker file(LD_FILES = boards/stm32f405.ld boards/common_ifs.ld) i didn´t get what i should change .
And is there any other file i should change .
This is the change that i made for the mpconfigboard.h :
#define MICROPY_HW_BOARD_NAME "F4"
#define MICROPY_HW_MCU_NAME "STM32F417"
// HSE is 8MHz
#define MICROPY_HW_CLK_PLLM (4)
#define MICROPY_HW_CLK_PLLN (168)
#define MICROPY_HW_CLK_PLLP (RCC_PLLP_DIV2)
#define MICROPY_HW_CLK_PLLQ (7)
I want to get that project done as soon as possible , any help will be apreciated .
Thank you in advance
