cannot connect sd card
tecdroid
Post by tecdroid » Thu Jun 03, 2021 1:28 pm
i try to customize mp for a board based on stm32f407vgt6 which is basically the same chip family as pyboard is but having 100pins. (i don't use ethernet feature of 407 yet) this board this is the schematic
Main differences I have found so far - the board that i have doesn't have VBUS-DETECT or OTG-Pin. Compiling without those helped getting a prompt via USB.
I cannot get an SD Card container run yet. this one. Concerning to mp doc, I should have a machine.SDCard. What i've found is pyb.SDCard.
When i try this
>>> from pyb import SDCard
>>> uos.mount(SDCard(), '/sd')
OSError: [Errno 19] ENODEV
using the information from existing board configurations I connected (hopefully, this is right) SD_D0 (MISO) to PC8, SD_CMD (MOSI) to PD2 and SD_CK (CLK) to PC12. Chip select is tied to GND. Bus width is set to 1 - because I only get one miso out of that card container
here's my mpconfiguration.h:
#define MICROPY_HW_BOARD_NAME       "MILLISCAN"
#define MICROPY_HW_MCU_NAME         "STM32F407"
#define MICROPY_PY_UASYNCIO     (1)
#define MICROPY_HW_HAS_SWITCH       (0)
#define MICROPY_HW_HAS_FLASH        (1)
#define MICROPY_HW_ENABLE_RNG       (1)
#define MICROPY_HW_ENABLE_RTC       (1)
#define MICROPY_HW_ENABLE_DAC       (1)
#define MICROPY_HW_ENABLE_USB       (1)
// HSE is 8MHz
#define MICROPY_HW_CLK_PLLM (8)
#define MICROPY_HW_CLK_PLLN (336)
#define MICROPY_HW_CLK_PLLP (RCC_PLLP_DIV2)
#define MICROPY_HW_CLK_PLLQ (7)
// UART config
#if 1
// A9 is used for USB VBUS detect, and A10 is used for USB_FS_ID.
// UART1 is also on PB6/7 but PB6 is tied to the Audio SCL line.
// Without board modifications, this makes UART1 unusable on this board.
#define MICROPY_HW_UART1_TX     (pin_A9)
#define MICROPY_HW_UART1_RX     (pin_A10)
#endif
#define MICROPY_HW_UART2_TX     (pin_A2)
#define MICROPY_HW_UART2_RX     (pin_A3)
#define MICROPY_HW_UART3_TX     (pin_D8)
#define MICROPY_HW_UART3_RX     (pin_D9)
#if MICROPY_HW_HAS_SWITCH == 0
// NOTE: A0 also connects to the user switch. To use UART4 you should
//       set MICROPY_HW_HAS_SWITCH to 0, and also remove SB20 (on the back
//       of the board near the USER switch).
#define MICROPY_HW_UART4_TX     (pin_A0)
#define MICROPY_HW_UART4_RX     (pin_A1)
#endif
// NOTE: PC7 is connected to MCLK on the Audio chip. This is an input signal
//       so I think as long as you're not using the audio chip then it should
//       be fine to use as a UART pin.
#define MICROPY_HW_UART6_TX     (pin_C6)
#define MICROPY_HW_UART6_RX     (pin_C7)
// I2C buses
#define MICROPY_HW_I2C1_SCL (pin_B6)
#define MICROPY_HW_I2C1_SDA (pin_B7)
#define MICROPY_HW_I2C2_SCL (pin_B10)
#define MICROPY_HW_I2C2_SDA (pin_B11)
// SPI buses
#define MICROPY_HW_SPI1_NSS  (pin_A4)
#define MICROPY_HW_SPI1_SCK  (pin_A5)
#define MICROPY_HW_SPI1_MISO (pin_A6)
#define MICROPY_HW_SPI1_MOSI (pin_A7)
#define MICROPY_HW_SPI2_NSS  (pin_B12)
#define MICROPY_HW_SPI2_SCK  (pin_B13)
#define MICROPY_HW_SPI2_MISO (pin_B14)
#define MICROPY_HW_SPI2_MOSI (pin_B15)
// CAN buses
#define MICROPY_HW_CAN1_TX (pin_B9)
#define MICROPY_HW_CAN1_RX (pin_B8)
#define MICROPY_HW_CAN2_TX (pin_B13)
#define MICROPY_HW_CAN2_RX (pin_B12)
// USRSW is pulled low. Pressing the button makes the input go high.
#define MICROPY_HW_USRSW_PIN        (pin_A0)
#define MICROPY_HW_USRSW_PULL       (GPIO_NOPULL)
#define MICROPY_HW_USRSW_EXTI_MODE  (GPIO_MODE_IT_RISING)
#define MICROPY_HW_USRSW_PRESSED    (1)
// USB config
#define MICROPY_HW_USB_FS              (1)
//#define MICROPY_HW_USB_VBUS_DETECT_PIN (pin_A9)
//#define MICROPY_HW_USB_OTG_ID_PIN      (pin_A10)
// SD Card
#define MICROPY_HW_ENABLE_SDCARD (1)
//#define MICROPY_HW_SDCARD_CK (pin_C12)
//#define MICROPY_HW_SDCARD_D0 (pin_C8)
//#define MICROPY_HW_SDCARD_CMD (pin_D2)
#define MICROPY_HW_SDCARD_BUS_WIDTH (1)
Soo.. what did I do wrong?
