how tu unlock raspberry pi PICO?
wojtekizk
Post by wojtekizk » Thu Aug 05, 2021 11:49 am
Hi ... I will unlock accidentally stuck raspberry pico after using machine.freq (250,000,000). Currently, the COM port is not visible. After loading the UF2 file, the COM port appears for a moment and then PICO starts up with its loaded program. The COM port is no longer visible.
Re: how tu unlock raspberry pi PICO?
Post by jimmo » Thu Aug 05, 2021 12:26 pm
Does your main.py set machine.freq(250000000) ?
You'll need to erase the entire flash of your Pico to reset the filesystem (and remove main.py)
The easiest way to do this is with the flash_nuke.uf2 firmware (just program this like any other firmware, and then you can put micropython back on). Direct link is https://www.raspberrypi.org/documentati ... h_nuke.uf2 but you see the details at the bottom of https://www.raspberrypi.org/documentati ... ifications
Post by pythoncoder » Fri Aug 06, 2021 9:09 am
As a general tip, if you use main.py to run a program it's a good idea to put in a delay. This gives you time to break in and interrupt it with ctrl-c if the code makes the machine unusable.
# main.py
time.sleep(4)
import my_program  # Run the application
