I am using (as always) vmware VMs, in this case I am using Alpine since it is lightweight and fast, and have as far as I can tell installed all of the dependencies including replacing ash with bash as the install scripts all seem to be written for bash.
I have decided to use the functions in
micropython/micropython/tools/ci.sh ci_esp32_setup_helper
The installation completes successfully, and ends with the message to source the exports.sh file, and this is where I am stuck, and I am getting a lot of errors:
Adding ESP-IDF tools to PATH...
ERROR: tool xtensa-esp32-elf has no installed versions. Please run '/nfs/qnap/dev/upydev/build/esp/esp-idf/install.sh' to install it.
ERROR: tool esp32ulp-elf has no installed versions. Please run '/nfs/qnap/dev/upydev/build/esp/esp-idf/install.sh' to install it.
ERROR: tool openocd-esp32 has no installed versions. Please run '/nfs/qnap/dev/upydev/build/esp/esp-idf/install.sh' to install it.
idf_tools.py export
Re-running the install script makes no difference, no errors are hit during installation, and only info messages stating that the tool is already installed, and will be re-installed.
Depending on the version I install, the number of these failures increases as the version increases from v4.0.2, v4.1.1 or v4.2, and I have re-done the install process at least 1/2 dozen times today, the result is always the same and fails at this stage.
I also used my previous debian distro, and the errors defined above are the same on both debian and alpine distros.
I have googled these errors, but have not found a solution.
Has anyone else recently used the ci.sh functions to build the esp environment, or has anyone else encountered and solved similar errors ?
Thanks in advance
