I'm new to MicroPython and Python in general so please forgive me if this is a stupid question.
I'm trying to use a Raspberry Pi Pico with an MCP23017. So in order to install the MCP library i do this:
python3 -m pip install adafruit-circuitpython-mcp230xx
When I try to run the program to connect to the MCP23017 I get a
Module not found: digitalio
As far as I can see I need to install adafruit-micropython-blinka to fix that problem
But when I try to do that I get an error:
python3 -m pip install adafruit-micropython-blinka
Password:
WARNING: The directory '/Users/persommer/Library/Caches/pip' or its parent directory is not owned or is not writable by the current user. The cache has been disabled. Check the permissions and owner of that directory. If executing pip with sudo, you should use sudo's -H flag.
Collecting adafruit-micropython-blinka
Downloading Adafruit-Micropython-Blinka-1.0.0.tar.gz (11 kB)
Preparing metadata (setup.py) ... error
ERROR: Command errored out with exit status 1:
command: /usr/local/opt/python@3.10/bin/python3.10 -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/private/tmp/pip-install-3air0m4f/adafruit-micropython-blinka_07c2d03c265b433fa85018754a5b01b9/setup.py'"'"'; __file__='"'"'/private/tmp/pip-install-3air0m4f/adafruit-micropython-blinka_07c2d03c265b433fa85018754a5b01b9/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /private/tmp/pip-pip-egg-info-z5z44ov_
cwd: /private/tmp/pip-install-3air0m4f/adafruit-micropython-blinka_07c2d03c265b433fa85018754a5b01b9/
Complete output (5 lines):
File "<string>", line 1, in <module>
File "/private/tmp/pip-install-3air0m4f/adafruit-micropython-blinka_07c2d03c265b433fa85018754a5b01b9/setup.py", line 39, in <module>
with open(os.path.join(here, 'src', '__version__.py')) as f:
FileNotFoundError: [Errno 2] No such file or directory: '/private/tmp/pip-install-3air0m4f/adafruit-micropython-blinka_07c2d03c265b433fa85018754a5b01b9/src/__version__.py'
WARNING: Discarding https://files.pythonhosted.org/packages/31/e4/9ceebeb7a811cce5a1c9cb47a31e51c82a25e2a7f8d97656f7ef27703f2e/Adafruit-Micropython-Blinka-1.0.0.tar.gz#sha256=fb0af4bbcd50c92966c13d29455b5c0ca1d7aca011885c6971723df9e7cedc26 (from https://pypi.org/simple/adafruit-micropython-blinka/) (requires-python:>=3.6.0). Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
ERROR: Could not find a version that satisfies the requirement adafruit-micropython-blinka (from versions: 1.0.0)
ERROR: No matching distribution found for adafruit-micropython-blinka
I'm on MacOS on an M1 MacMini
I hope someone can help me out!
Thank you!
