hi again,
stupid question. How can I determine the size of my compiled micropython to fit it into my flash.
standard stm32 only has 90kb of program space left and i wonder if i can resize it a little..
btw: is micropython capable of handling spi flash like AT45DB321E-SHF and how do i tell it to use it?
how to determine needed flash size
Re: how to determine needed flash size
When you build the firmware, it prints the size, something like this: The size of the "text" section is the amount of space needed for code. The "data" section corresponds to global variables, and their initial value is stored in flash. The values used during runtime is stored in RAM. The "bss" section is zero-ed global variables and is only stored in RAM.
So the total amount of flash needed is text + data + filesystem
The total amount of RAM needed is data + bss + stack + heap.
LINK build-PYBV11/firmware.elf
text data bss dec hex filename
368392 16 27424 395832 60a38 build-PYBV11/firmware.elf
This is another stupid question. What is current maximum compiled flash size that we can reach on ESP8266, ESP32GENERIC and ESP32 SPIRAM.
your response is much appreciated,
