Building without the REPL
cduran
Post by cduran » Wed May 18, 2022 7:07 pm
Is it possible to build MP without the REPL? I'm using MP embedded in another application. Currently I just disabled the UART code, but I would feel more comfortable if I could just eliminate the REPL. I want to do this for security reasons, NOT for memory savings.
Re: Building without the REPL
Post by Roberthh » Thu May 19, 2022 11:16 am
Look into main.c of the board in question. There, REPL is called after executing main.c. You should be able to change the code accordingly.
cduran
Post by cduran » Mon May 23, 2022 12:43 pm
Thank you, this was a lot of help.
