Building the unix port as a library (.a file)
cduran
Post by cduran » Wed Jul 06, 2022 6:59 pm
I've had success building the minimal port as a library (.a) but when I try the same with the Unix port I get a lot of undefined objects despite the source compiling properly.
To make the library I add the following:
staticlib: $(OBJ)
	$(Q)$(AR) -r -o libmicropython.a $(OBJ)
to the Unix port makefile. When I try to link in the library (I make sure I have all the header files) to my application I get a slew of undefined functions and structs. When I look at the contents of the mp object files (using nm) it shows that those functions and structs are indeed not defined in the object files. I don't think the problem is with AR, there must be something I can't pinpoint myself in the Unix port makefile that is causing this.
Re: Building the unix port as a library (.a file)
Post by jimmo » Thu Jul 07, 2022 12:43 am
Can you post some examples of the missing symbols and also a minimal example of a program linking against your static library.
cduran
Post by cduran » Fri Jul 08, 2022 12:41 pm
These are the undefined symbols. Note they are also undefined in their corresponding object files.
undefined reference to `mp_hal_stdout_tx_strn_cooked'
undefined reference to `mp_builtin_open_obj'
undefined reference to `gc_collect'
undefined reference to `mp_hal_set_interrupt_char'
undefined reference to `mp_module_time'
undefined reference to `mp_unix_free_exec'
undefined reference to `mp_stderr_print'
undefined reference to `mp_module_uselect'
undefined reference to `mp_module_machine'
undefined reference to `mp_module_os'
undefined reference to `mp_unix_alloc_exec'
I'll post how it's being linked shortly. However, wouldn't the problem be in how the library is being built? The symbols are undefined in the static library, so no matter how the static library is link to my program, those symbols are not there.
Post by jimmo » Mon Jul 11, 2022 6:10 am
I added exactly the fragment you posted to unix/Makefile and I get (for example, gc_collect)
$ nm libmicropython.a | grep 'gc_collect'
                 U gc_collect
0000000000000000 T gc_collect_end
0000000000000000 T gc_collect_root
0000000000000000 T gc_collect_start
                 U gc_collect
0000000000000000 D gc_collect_obj
0000000000000000 t py_gc_collect
0000000000000000 T gc_collect                           <------------
                 U gc_collect_end
                 U gc_collect_start
                 U gc_collect_root
                 U gc_collect_root
                 U gc_collect_root
cduran
Post by cduran » Thu Jul 21, 2022 4:59 pm
                 U gc_collect
                 U gc_collect
                 U gc_collect_end
                 U gc_collect_start
                 U gc_collect_root
                 U gc_collect_root
                 U gc_collect_root
Thank you for the help...finally found out what my problem was. I wasn't including any of the lib files into the compile. I simply removed the main function from main.c and compiled with main.c included. That did the trick.
