How to run micropython-lib to pyboard v10
Micropython-lib is very usefully,but how to run micropython-lib to byboard v10.Thanks!
Re: How to run micropython-lib to pyboard v10
Copy the relevant files from the library to the Pyboard flash (or SD card if you're using one). So, for example, say you're using pickle you'd copy the file pickle.py from the pickle subdirectory of the library to your device.
ok.Thanks pythoncoder .
