I searched for any one else having the same issues I found nothing, so here goes.
I was following the instructions to build a native OSX binary at :
https://github.com/micropython/micropyt ... ng-Started
And they didn't work for me. This on OS X 10.11.6 with libffi installed via brew.
To get a working build I used the following steps:
git clone --recurse-submodules https://github.com/micropython/micropython.git
cd micropython/unix
export PKG_CONFIG_PATH=/usr/local/opt/libffi/lib/pkgconfig
make libffi axtls
make MICROPY_PY_BTREE=0
So I have 3 questions :
Is it expected that you have to turn off the berkley db off to get a successful compile?
Is it expected that you have to make libffi and axtls first ?
Should I update https://github.com/micropython/micropyt ... ng-Started with these extra steps ?
Thanks!
Issues compiling on OSX
Re: Issues compiling on OSX
On El Capitan this works for me:
I am not sure about the CFLAGS bit. All of my ports fail to compile unless I unset it.
brew install libffi
brew install pkgconfig
brew install python3
cd micropython/unix
unset CFLAGS
make clean
PKG_CONFIG_PATH="/usr/local/opt/libffi/lib/pkgconfig" LDFLAGS="-L/usr/local/opt/libffi/lib" make axtls
MISC Preparing upip as frozen module
../tools/make-frozen.py build/frozen_upip/ > build/_frozen_upip.c
LINK micropython
__TEXT __DATA __OBJC others dec hex
335872 49152 0 4294997728 4295382752 1000656e0
./micropython
MicroPython v1.8.3-136-ga50b26e-dirty on 2016-10-14; darwin version
>>> 1/3
0.3333333333333333
PKG_CONFIG_PATH="/usr/local/opt/libffi/lib/pkgconfig" LDFLAGS="-L/usr/local/opt/libffi/lib" make test
cd ../tests && MICROPY_MICROPYTHON=../unix/micropython ./run-tests
pass basics/0prelim.py
pass unix/ffi_float2.py
527 tests performed (17288 individual testcases)
527 tests passed
7 tests skipped: cmd_showbc cmd_verbose framebuf1 urandom_extra vfs_fat_ramdisk buffered_writer extra_coverage
echo $CFLAGS
-I/usr/local/include
